Where does the front fork sit? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
  • 1 Post By MAZ4ME
  • 1 Post By MAZ4ME
  • 2 Post By Brockie
  • 5 Post By thirdofthree
  • 2 Post By Highwayman2016
  • 1 Post By branthopolis
post #1 of 9 Old 03-12-2019, 11:42 PM Thread Starter
The PO of my bike lowered the ride 3/4" with AdventureTech links as well as dropping the front forks. I want to raise it back up by putting the original links back on and raising the front forks. When I look at the front forks the fork tube tapers just a tiny bit before the cap. On all my other bikes the stock position is with the top of the fork tube flush with the tree. If I do that with my '12 DL650 the the tapered portion would sit below the top of the tree. What should I put flush with the top of the tree: the top of the tube or where it starts to taper? Dropping an absolute 3/4" of an inch would put it with the top of the tube flush. Can anyone look at their stock '12 DL650 and advise? I've attached a photo to show where it is now....
Thanks!
Got the heart attack over and done with - Prudhoe Bay or Bust!
slane6 is offline
post #2 of 9 Old 03-12-2019, 11:58 PM
From your pic it appears there is a 1/8" wintness mark where the fork originally sat in the upper triple clamp. Look at the junction of the cap and upper fork tube--about 1/8" below that it looks like that area was in the clamp.
Brockie likes this.
MAZ4ME is offline
post #3 of 9 Old 03-13-2019, 12:01 AM Thread Starter
That 1/8" inch is the taper I was talking about....
slane6 is offline
post #4 of 9 Old 03-13-2019, 12:04 AM
I'll check, but I believe the upper tube sits in the upper clamp at the bottom start of that taper. I'll check on a friend's '14 DL650, same series as your '12.
slane6 likes this.
MAZ4ME is offline
post #5 of 9 Old 03-13-2019, 12:23 AM
Brockie's Avatar
The fork cap of my 09 Wee sits proud of the upper tree with no fork tube visible, although many recommend the fork tube sitting 15mm through the upper tree for better handling.
slane6 and branthopolis like this.
Brockie is online now
post #6 of 9 Old 03-13-2019, 12:58 AM
My 2015 DL650 is same as described by Brockie.
File Type: jpg 2015 DL650 upper tree fork tube position.jpg (359.7 KB, 9 views)
thirdofthree is offline
post #7 of 9 Old 03-13-2019, 01:14 AM
Highwayman2016's Avatar
Here’s my 2014.
Gert and slane6 like this.
2014 650 Strom
Highwayman2016 is offline
post #8 of 9 Old 03-13-2019, 11:47 AM Thread Starter
Thank you all! That is the confirmation I was looking for
slane6 is offline
post #9 of 9 Old 03-13-2019, 03:41 PM
branthopolis's Avatar
Yep.. Having the front sit a bit lower than stock (with the rear at stock height) will steepen the steering angle and make the bike quicker to steer... If you like to rail the twisties it can be fun to play with.. Have to be careful not to go too far with it though...
slane6 likes this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
Front Fork Oil Seal Replacement - One Tip taz_co Maintenance How-to 8 11-04-2018 10:33 AM
Front fork springs upgrade HiPERnx DL650A - 2017+ 3 09-18-2018 07:24 PM
front fork protection? slickster57 General V-Strom Discussion 8 12-26-2013 09:11 PM
Front fork query herdygerdy DL650 and DL650A - 2004 to 2011 6 02-11-2013 11:12 PM
