Loose frame and engine mount bolts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By dmfdmf
  • 1 Post By Brockie
  • 1 Post By Dodobo
post #1 of 8 Old 03-11-2019, 09:39 PM Thread Starter
rattlinjack's Avatar
A question to all you long term Wee operators, users, abusers!
2015 DL650A. 25,000 Ks
Bike started "creaking and groaning" more than usual.
Found one engine bolt and four sub frame bolts loose. One sub frame bolt missing...
I probably spend more time offroad than this bike is designed for. Mainly forestry tracks, fire roads and the like. A lot of high speed short sharp impacts involved..
A lot of our sealed roads out in the country are worse than the dirt tracks themselves. Sometimes it's a relief to get back on to the dirt
after 50Ks of patched tar roads.
SOOO my question is, what else should I be looking at, as far as fittings, nuts, bolts etc?
rattlinjack is offline
post #2 of 8 Old 03-12-2019, 01:52 AM
dmfdmf's Avatar
Motor Mount Reseat & Retorque.
rattlinjack likes this.
Next Up: ?
dmfdmf is offline
post #3 of 8 Old 03-12-2019, 02:03 AM
Brockie's Avatar
Replace the lost bolt and removing one at a time apply blue Loctite and torque to specification. Check the torque of all other engine/frame bolts.
Are you the original owner? Could a PO have fitted and removed crash bars etc?
Spec likes this.
Brockie is online now
post #4 of 8 Old 03-12-2019, 03:21 AM Thread Starter
Originally Posted by dmfdmf View Post
Good info, thanks!
My Bike is "quiet" on the road at any speed, but there was some groaning from the chassis when moving the bike around in the shed etc. All good after re torquing all the bolts I could get at, without removing anything.
Will have to check further before next big ride...
post #5 of 8 Old 03-12-2019, 03:26 AM Thread Starter
Good call...
I put the crash bars on and yep, they were all loose...
That long through the top engine mount, was the main culprit me thinks..
post #6 of 8 Old 03-12-2019, 01:27 PM
Thanks for the reminder to check the torque on all those frame/engine bolts! FYI - the owners manual has a page with a picture of the bike with all the bolts you should periodically check highlighted and their torque specs.
And for anyone else with a rattle, I just discovered my front fender is cracked right behind where it mounts to the fork. At various RPMs it will resonate and make quite the racket. This was caused by getting too full of mud so I guess I found out why they make fender risers...
Dodobo is offline
post #7 of 8 Old 03-12-2019, 02:11 PM
dravnx's Avatar
I had the same place crack because I replaced the shoulder bolt with a non-shouldered bolt. The non-shouldered bolt squeezes the plastic too much and causes it to crack.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #8 of 8 Old 03-12-2019, 07:38 PM
Brockie's Avatar
Take it off and have it plastic welded or JB Weld the crack and inside the guard. It will just get worse until one day it will break off. I dislike roadside breakdowns.
Motor Mount Reseat & Retorque dmfdmf Maintenance How-to 6 08-06-2019 11:41 AM
Installing a B&B Bash Plate on 2012 V-Strom DL650A Dave.A Maintenance, Tech and Products. 8 07-01-2016 05:52 AM
Vee 2 - Front engine mount alignment troubles (Installing skid plate) disassembled V-Strom Service and Maintenance Questions and Discussions 6 10-14-2015 06:01 AM
DL650 + TN532 Givi engine guards + frame sliders llaman DL650A - 2012-2016 11 04-02-2015 03:07 PM
SV Racing Frame and Swingarm slider install PICS! (On an Adventure w/ Crash Bars) Pele2048 DL650A - 2012-2016 5 11-12-2013 07:22 AM
