Oil Consumption (burnt) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 28Likes
post #1 of 34 Old 03-05-2019, 07:23 PM Thread Starter
JonathanAU's Avatar
Hi guys:
I notice in my last trip that my bike was consuming oil , burn it, 'cause where else could it go
It was in summer, so temp was between 25 to 39 Celsius (yes it was hot)
I rode about 940 km in 3 days including offroad , and I had to add up 300ml of engine oil back home.
My bike is a 2016 650 XT, almost 2 years old and 26.400+ km. Normally used as a commuter, sometimes a trip on weekends. Yes, I like to start hard on traffic light and leave the cars behind. Usually riding between 4,000 and 7,000 rpm.
24k service was made about 2 - 3 months ago, including valve clearance check. (I hope all was put back together correctly by the mechanic)
Has anyone have the same oil consumption issue ?
Is it normal?
JonathanAU is offline
post #2 of 34 Old 03-05-2019, 11:07 PM
blaustrom's Avatar
On the older WEE 650 engines it was the common understanding that that engine would burn some oil when running for extended periods at higher revs, regardless of engine age. If I remember right Greywolf was theorizing that there were some oil fumes getting into the airbox and some get consumed, some drop back down.
My Wee would burn some oil when running hard for hours on the interstate but basically non when cruising around regionally.
HokiesRWee, VSrider, Gert and 4 others like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 34 Old 03-05-2019, 11:36 PM Thread Starter
JonathanAU's Avatar
thanks for that answer Blaustrom, it give me a bit of peace of mind, but still worries me a bit. May I need to carry a can of oil in a long trip then ?
Also well done by remembering Greywolf.
post #4 of 34 Old 03-05-2019, 11:39 PM
That's not abnormal at all.......no worries.
JonathanAU likes this.
post #5 of 34 Old 03-06-2019, 09:24 AM
blaustrom's Avatar
I did. I added one of those "tool tube" containers to my setup and found a drink bottle that fit nicely inside and had that filled with oil. But that was only ever used when tracking 2k miles going out west across the continent.
Blau2 2014 DL1000A
post #6 of 34 Old 03-06-2019, 12:20 PM
V-Tom's Avatar
Hi guys:
Is it normal?
Some oil consumption is normal, especially with higher revs. There is one other thing that can be at play:
If your normal riding mainly short trips of less than half an hour and/ or you "warm it up" by sitting there idling for a while there is a tendency for water vapour to condense in the crankcase and get absorbed into the oil. When the oil gets good and hot the water essentially boils out and the oil level can appear to drop.
..Tom
Brockie and Chipwidget like this.
SMIDSY detailed report.
V-Tom is offline
post #7 of 34 Old 03-06-2019, 12:33 PM
I've noticed my '04 Wee uses oil as you describe but I've got 99.5K miles on the engine. I usually carry a 1/2 liter bottle of oil with me on extended mile trips.
GW suggested that a full oil fill on the site glass, as seen on the centerstand, would be at the top of the glass.
I start that way and if it drops to below the center of the glass, I add some.
After hours at 70+ mph the level drops. I don't notice an overly sooty tailpipe and it doesn't feel greasy, I don't have oil spots on the ground where I'm parked so I don't worry about it.
post #8 of 34 Old 03-06-2019, 12:55 PM
Have you dropped your bike by any chance? ( you mentioned off road riding)
Motor7 likes this.
Rick123 is offline
post #9 of 34 Old 03-06-2019, 01:05 PM
Motor7's Avatar
Yep, that will send some into the bottom half of the air filter clam-shell....been there, done that, will do it again.
'15 DL650XT
Motor7 is offline
post #10 of 34 Old 03-06-2019, 01:32 PM
D.T.'s Avatar
There is an oil coalescer in the air box. They disintegrate over time. You can check that. Should catch oil vapors.
My SV had a bad oil ring and was using a lot of oil so I had to get new rings. Could be cylinder scratched too. Bad valve guide seals will blow smoke on start up.
D.T. is offline
Oil Consumption Problem?? big-w DL650A - 2012-2016 37 03-05-2015 10:42 AM
Fuel Consumption for a K2 Vee Cabbage Mechanic V-Strom Modifications and Performance 0 04-28-2012 08:33 AM
