Oil Consumption (burnt) - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 28Likes
post #31 of 34 Old 03-09-2019, 05:46 PM
itlives's Avatar
On my post saying 130f across Death Valley, I was guessing . I did have my evaporative cooling jacket on and do not think I would have faired well without it. The irony is I was supposed to go to Redding and it was 112f that day! Wtf- I left Louisiana looking for lower temps!
itlives is offline
post #32 of 34 Old 03-11-2019, 11:15 PM Thread Starter
JonathanAU's Avatar
Originally Posted by V-Harry View Post
Got thinking about no drain on air box and there has to be one.
See from manual.
Jonathon pull this plug and see if any oil present, worth a look.
Harry
that is good idea , if traces of oil are in there, the mystery is solved.
I have been checking the oil levels and it's been the same in last 2 weeks.
Also my best fuel consumption ever was in that trip where the oil disappeared.
JonathanAU is offline
post #33 of 34 Old 03-11-2019, 11:20 PM Thread Starter
JonathanAU's Avatar
Originally Posted by V-Tom View Post
It hit 126F when I went through Death Valley in 2011 on my 2006 DL650. (Actual moving at speed temperature.)
..Tom
Originally Posted by ddphillips View Post
Rode a 2012 with 42,000kms from sydney to adelaide in 43c temps after buying it, no noticeable oil usage over 1,400kms. Same engine at 61,000kms no oil usage issues, you can buy that engine if you want- cheap too!
yeeeeh that's insanely hot, I think I like temps under 32 degrees C more. My top have been 39 - 40 C and I was not enjoying it so much. Although pour water over myself was satisfying , riding wet (dripping from heat to toe) was a new experience, valid if you have to ride in hot environments .
post #34 of 34 Old 03-18-2019, 03:43 PM
My Triumph Sprint used a little oil. Triumph suggested that it was ok to burn some oil up to 1 quart / 1000 miles!
itlives and JonathanAU like this.
2013 DL650A, OEM centerstand, Powerlet outlet, Parabellum windshield with X-screen deflector.
scritch is offline
Oil Consumption Problem?? big-w DL650A - 2012-2016 37 03-05-2015 10:42 AM
Fuel Consumption for a K2 Vee Cabbage Mechanic V-Strom Modifications and Performance 0 04-28-2012 08:33 AM
