Oil Consumption (burnt) - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 28Likes
post #21 of 34 Old 03-06-2019, 10:30 PM
V-Tom's Avatar
Originally Posted by JonathanAU View Post
hmmm , considering that the oil temp of an operative / warmed up engine is about 90 Celsius (5 min ride will give you that temp), and water evaporates at 100. I don't think water plays a big role there. it would be very visible in the oil glass as water does not mixes with oil at all.
I mean 200cc - 300 cc of oil is the difference between Low and High marks .
It takes a lot longer than 5 min to get oil up to temperature. Coolant perhaps but not oil. I suspect 10 to 20 minutes at least and likely longer to get the oil to boiling point as the oil cooler is so efficient. Plus 2012+ DL650's have a history of showing condensation in the oil level sight Guage.
..Tom
Brockie likes this.
2015 DL1000 New July 2015 180,000+ km, 112,000 miles.
SMIDSY detailed report.
V-Tom is offline
post #22 of 34 Old 03-07-2019, 01:11 AM
Hi JonathanAU
Rode to Darwin two up last May, 2013 Vstrom.
33 to 37 Celsius most days, no oil drop at all.
Speeds 100 to 120kms.
I'd say maybe the drops could have something to do with it.
Top up ride again and check.
I"m sure the air box would have a drain tube, so maybe bike upright ride away and oil in box drained off.
If all good after next ride no worries.
Enjoy
Harry
JonathanAU likes this.
V-Harry is offline
post #23 of 34 Old 03-07-2019, 09:23 AM
There is no designated low spot in the air box that I know of for a drain tube. It would have to have a valve in it to keep air from being sucked in from that too.
What goes in the air box stays in the air box until it gets cleaned out.
JonathanAU and V-Harry like this.
post #24 of 34 Old 03-07-2019, 09:58 PM
itlives's Avatar
Very high temps and long rides tend to burn a little oil, from my experience. But, my experience is not on the Wee. My Super Tenere burned 1/2 quart going through Death Valley. It was the only time it ever used any oil. I had to look up the Celsius to F . 39 C is 102 f . I'm sure it was 130F going through the valley!
itlives is offline
post #25 of 34 Old 03-07-2019, 10:57 PM Thread Starter
JonathanAU's Avatar
130F is like 54C ... are you sure?.. that is insane , you would have die of a stroke or some shit.
V-Harry likes this.
JonathanAU is offline
post #26 of 34 Old 03-07-2019, 11:09 PM
V-Tom's Avatar
It hit 126F when I went through Death Valley in 2011 on my 2006 DL650. (Actual moving at speed temperature.)
..Tom
Big B likes this.
V-Tom is offline
post #27 of 34 Old 03-07-2019, 11:14 PM
ddphillips's Avatar
Rode a 2012 with 42,000kms from sydney to adelaide in 43c temps after buying it, no noticeable oil usage over 1,400kms. Same engine at 61,000kms no oil usage issues, you can buy that engine if you want- cheap too!
V-Harry likes this.
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
post #28 of 34 Old 03-08-2019, 02:56 AM
Hi Notacop
Thanks for the info on the air cleaner, just about to change mine for the first time.
Harry
V-Harry is offline
post #29 of 34 Old 03-08-2019, 06:19 AM
Got thinking about no drain on air box and there has to be one.
See from manual.
Jonathon pull this plug and see if any oil present, worth a look.
Harry
slane6 and JonathanAU like this.
V-Harry is offline
post #30 of 34 Old 03-08-2019, 07:51 AM
Oil bath and severe mechanical action will cause oil to atomize.
Atomized oil will leave with the blow by gas
Oil/air separator in airbox will not collected very small atomized droplets
Atomized droplets will be drawn in to the intake and lubricate the top end
it's a feature !
richw is offline
Oil Consumption Problem?? big-w DL650A - 2012-2016 37 03-05-2015 10:42 AM
Fuel Consumption for a K2 Vee Cabbage Mechanic V-Strom Modifications and Performance 0 04-28-2012 08:33 AM
