Givi airflow install advice - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 13 Old 03-04-2019, 11:43 PM Thread Starter
Snowlover's Avatar
Just got my givi from motostorm and it looks awesome but instructions are not in English. What holes are recommended for the base? 6’ with 32”inseam. I will experiment but wondered what was the best height to start with.
So many roads, so little time !
Snowlover is offline
post #2 of 13 Old 03-05-2019, 02:19 AM
Brockie's Avatar
Setup is very much individual to each rider as bars, seat and physique create many variables.
I used the lower mounts - after all the top screen is adjustable to your preference anyway. I've ended up happy with the upper screen adjusted to near its lowest setting with the top edge of the screen just below the horizon. What a HUGE difference it makes at motorway speeds.
Brockie is offline
post #3 of 13 Old 03-05-2019, 06:41 AM
Motor7's Avatar
Mine is set up exactly like Brockie's....low. I hate looking through any windshield and with the AF I don't have too.
'15 DL650XT
Motor7 is offline
post #4 of 13 Old 03-05-2019, 07:13 AM
I have started with it all up ! It depends outside temperature , speed ,etc. Now i tend to lower it as above . Ride safe!
Grigore Lazarescu is offline
post #5 of 13 Old 03-05-2019, 08:06 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
The airflow is effectively taller than it's physical dimensions due to it's excellent control of the air flow. I start suggest starting with it placed about an inch below you noral line of site and go from there.
https://www.adventuretech.biz/windshields.html
richlandrick is offline
post #6 of 13 Old 03-05-2019, 09:20 AM
I'm 5'11", 32" inseam. I started with the base mounted in the lowest position. Generally fine for me, with one exception: in those instances I wanted the most wind protection with the upper portion raised, I experienced buffeting that kept knocking my visor down at highway speeds (I ride with it up 99% of the time).
I eventually moved the base from the lowest holes to the highest holes. I didn't notice any change in performance with the upper portion low or midling. And with the upper portion at higher positions I enjoyed reduced buffeting.
I think my brothers -- same height and inseam -- have their base mounted in the lowest position.
Just have to pick one and try it, then switch it up if it's not quite right to see if an alternative base position works better.
thirdofthree is offline
post #7 of 13 Old 03-05-2019, 09:31 AM
grepper's Avatar
Hmmm, I'm 6 foot myself and went with the highest setting for the base, I like it there
Sent from my XT1254 using Tapatalk
Current bikes
2012 v-strom 650
2013 v-strom 650 (wife's)
2008 Kymco scooter (for my teenagers)
1981 Honda cb750K
1978 Yamaha xs650
1975 Honda cb750K (wifes)
1965 Suzuki K-11p (non-running)
grepper is offline
post #8 of 13 Old 03-05-2019, 06:15 PM
I'm 6' with a 33" inseam.
I initially mounted mine low. Upper portion removed was great for full air blast in Chicago summers. Upper portion extended as high as possible wasn't smooth enough for me at 85 mph on the slab.
So, I moved the base to its highest setting. Upper portion removed was still great for full air blast in Chicago summers. Upper portion extended as high as possible smoothed the ride dramatically at 85 mph on the slab.
Is it easy to remove the Madstat windshield entirely for full air blast?
Super simple with the Givi, obviously. That's my favorite feature.
You can also change the angle of the Givi a bit by mounting it with washers on the high or low mounting points to pitch it more or less vertical.
Whatever you get, fiddle with it a bit to get it locked in. If you hate it, sell it easily and then buy something else.
Sent from my Nexus 5X using Tapatalk
rodentface is offline
post #9 of 13 Old 03-05-2019, 08:57 PM Thread Starter
Snowlover's Avatar
Great advice. Mounted in low holes. Less sound from wind during freeway trip. Raised slide to highest position coming back, very nice. Kind of cold so I’ll mess with it as weather warms up. Happy so far.
Brockie likes this.
post #10 of 13 Old 03-06-2019, 04:35 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
Trial and error has always worked out for me. Except the time I tried to get off the roof without a ladder...
Coach23101 is offline
The buffeting and windscreen thread for the 2014-2016 DL1000A, the only one! RhinoVStrom DL1000A - 2014-2016 907 03-11-2019 08:31 AM
Givi Trekker Outback 37L panniers/cases review, long book version Mastery Product Reviews 45 10-11-2018 10:27 PM
Barkbusters and GIVI Airflow AF260 Gummybear DL650 and DL650A - 2004 to 2011 1 06-02-2018 07:31 AM
Hot Grips Install Advice JLW1829 V-Strom Modifications and Performance 5 01-06-2008 03:42 PM
