Headlights not working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 11 Old 03-03-2019, 04:57 PM Thread Starter
Hi guys started the bike up this morning and as soon as i pressed the start button the headlights went out. Got the little side lights but not main and dip beam. Checked the fuses for the headlights and both ok. I've seen a few answers when googling some say starter switch. One said a contact in the ignition switch. And others point to the block connection under the tank. How do i go about tracing where the fault is. Mine is a 2015 model only mod os heated grips wired into the heated grip terminal not the battery. Thanks guys.
willwoms is offline
post #2 of 11 Old 03-03-2019, 05:02 PM
chicago's Avatar
I would look for a discolored connection or use a probe/meter to isolate it. It is often in the starter switch but not always. Lots has been written re this issue as you are probably finding out with your search.
14 tooth for me
chicago is offline
post #3 of 11 Old 03-03-2019, 06:44 PM
One of MANY threads if you did a GOOGLE search.
https://www.stromtrooper.com/northwe...ights-out.html
post #4 of 11 Old 03-03-2019, 11:24 PM
blaustrom's Avatar
Well you mentioned all the possible problems. What have you done to troubleshoot?
I would disassemble the starter switch first, since that is frequently the issue. If that is clean and has good contact you need to find the connector some were around the radiator I think on your bike and make sure it has good contact and is not burned.
If both prove not to be the problem, report back.
And then consider to order a headlight relay kit from eastern beaver, if he offers one for your model, not sure.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 11 Old 03-04-2019, 05:35 AM Thread Starter
Looking like the starter switch if i push the start switch the lights come on and as soon as i release off they go again. Are the switches easy to open up its not going to come apart into a thousand pieces as soon as i take it off is it?
willwoms is offline
post #6 of 11 Old 03-04-2019, 08:46 AM
Motor7's Avatar
Be very careful taking the starter button/switch apart. There are plunger and spring metal contact strips and they are tiny. Drape something under the handlebar to catch the parts, take pic's as you go and open up the cluster. I took my '07's apart, and soaked the blackened contact strip in white vinegar for 5 min, rinsed and re-assembled. Then added the EB harness with relay's and I suggest getting a extra relay when you order the harness as I had one fail(rare).
Big B and slane6 like this.
'15 DL650XT
Motor7 is offline
post #7 of 11 Old 03-04-2019, 10:08 AM
chicago's Avatar
starter switch maintenance......
https://blacklabadventures.com/2012/...h-maintenance/
Big B, blaustrom and slane6 like this.
14 tooth for me
chicago is offline
post #8 of 11 Old 03-04-2019, 12:49 PM
BC Rider's Avatar
What you describe is the reverse of what should be happening. When the starter button is pressed the lights go out to give more juice to the starter. Arcing at the contacts causes resistance which leads to more arcing. Have a look at the info on the forum and you will be fine
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is online now
post #9 of 11 Old 03-06-2019, 02:48 AM Thread Starter
Cleaned the starter switch up and all seems good now thanks guys.
Big B likes this.
willwoms is offline
post #10 of 11 Old 03-06-2019, 12:54 PM
OK.....NOW you want to install headlight relays, trust me on this.
chicago, Motor7 and slane6 like this.
2012 DL1K Adv headlights not working remoandiris DL1000 from 2002-2012 22 10-09-2016 12:01 PM
K5 Wee Headlights - none of the usual suspects sgifford V-Strom Service and Maintenance Questions and Discussions 7 05-23-2015 12:21 PM
Are Headlights both on with Low Beam? Dave.A Australia-New Zealand 30 07-04-2014 11:43 PM
Coocase S48 Luxury Remote and Alarm quit working creisinger General V-Strom Discussion 3 11-10-2013 04:36 PM
