Blown ABS Control Unit / HU - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 16Likes
post #1 of 15 Old 02-24-2019, 09:07 PM Thread Starter
Welp, it seems that I have fried my "ABS Control Unit / HU" on my '12 DL650
Was working on the bike rerouting some wires and cables, disconnected the leads from the Eastern Beaver ABS Cut-Out Bypass switch and didn't notice that they grounded against the fork until I saw arcing. Turns out the switch is on the hot side of the relay fuse and I had forgot to disconnect the battery. When I turned the bike back on the ABS light came on and stayed on even over 5mph. Did the diagnostics and found I had a code 35 & 42. Cleared the codes but the 42 kept coming back. Ran those diags and it came back as a bad ABS Control Unit. I've really done myself in by not following standard practice and disconnecting the battery. Pissed.
So:
1) Any suggestions? I could ride without ABS but I'm headed to Alaska for 2 months this summer and would really like to have it..
2) Anyone have a line on a ABS Control Unit / HU part #55610-11J01? Partzilla has it for $1,382.76 and I'd really rather not spend that much. There is one on eBay for $400, but again... am hoping someone might have a bike they are parting out.
Any help would be greatly appreciated!
Got the heart attack over and done with - Prudhoe Bay or Bust!
slane6 is offline
post #2 of 15 Old 02-24-2019, 09:33 PM
Just asking...but did you check ALL the fuses with a 12VDC test lamp?
The lesson here is to disconnect the negative battery cable from the battery before attempting any electrical work on any vehicle.
Try THIS:BBA can remanufacture different types of abs - United States | BBA Reman
MAZ4ME is offline
post #3 of 15 Old 02-25-2019, 08:49 AM
Motor7's Avatar
If it is really fried then ebay would be my number one choice. Like Maz says, look for a blown fuse before throwing in the towel. Do you have the wiring harness schematics?
'15 DL650XT
Motor7 is offline
post #4 of 15 Old 02-25-2019, 10:33 AM
M7, it's a difficult concept for many to understand, but the days of "Get a code, get a part" are long gone, have been for many years.
The code(s) never tell you the failed part, just the area or system in which the failure occurred.
So many times a customer would come back to the parts department holding an oxygen sensor, telling the counterperson he was sold a bad 02 because he replaced it and the code came back. And that's just one of many examples
Motor7 likes this.
MAZ4ME is offline
post #5 of 15 Old 02-25-2019, 12:17 PM
Spec's Avatar
In your normal day to day riding have you ever activated the ABS?
Outside of an emergency you should never activate the ABS unless you're practicing panic stops or just want to see if it works! Don't even know it's there kind of thing.
I would ride it without ABS before I would spend big money, but that's just me!
Big B, Motor7, Grimmer and 2 others like this.
Spec is offline
post #6 of 15 Old 02-26-2019, 05:01 PM
ddphillips's Avatar
Hi, I am parting out most of my 2012 DL650, the ABS unit is all good, $220AUD, or $160USD sound OK, probably $50AUD postage, but I can confirm.
slane6 and Hatchi like this.
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
post #7 of 15 Old 02-26-2019, 05:06 PM
ddphillips's Avatar
Here is an image of the unit
Motor7 and slane6 like this.
Darren
post #8 of 15 Old 02-26-2019, 07:34 PM
Motor7's Avatar
'Boom' there ya go...........!
'15 DL650XT
Motor7 is offline
post #9 of 15 Old 02-26-2019, 07:39 PM
M7, it'd still a forehead-slapper to spend $220, time, and effort when the problem COULD be a blown $.45 fuse...
Big B likes this.
MAZ4ME is offline
post #10 of 15 Old 02-26-2019, 07:50 PM
Motor7's Avatar
yah...I am assuming he is searching for the fuse issue too..............
'15 DL650XT
Motor7 is offline
Cruise control on the 2014 Tman02 DL1000A - 2014-2016 42 10-06-2017 09:37 PM
Throttle Control or Electronic Cruise Control COrtega_06 DL1000A - 2014-2016 34 01-10-2017 05:29 PM
New "Smart Line" Cruise Control Ned General V-Strom Discussion 5 02-16-2015 08:48 PM
Lee Parks and his Total Control team will run the new training program in California OfirMX Riding Proficiency 4 12-29-2014 12:03 PM
Rostra Cruise Control Wiring Chuck in Indiana General V-Strom Discussion 6 01-16-2010 09:27 PM
