21 inch front wheel - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 25 Old 02-05-2019, 10:29 AM Thread Starter
Lightbulb 21 inch front wheel
Hey !
I own a 2016 Xt vstrom, with spoked wheels.
My idea would be to change only the rim and spokes for a 21-inch version. (but keep the hub, brakes ...)
someone already did that? (I saw some gs1200 on the web modified as well. but no vstrom)
The rim was easy to find (with tube) but which spokes would be compatible with the stock hub ?
thanks !
B0ttleneck is offline
post #2 of 25 Old 02-05-2019, 10:36 AM
Doubtful, or I am sure somebody would've done such by now.
post #3 of 25 Old 02-05-2019, 10:42 AM
vanislejay's Avatar
Spokes can be found in all sorts of lengths. Your biggest concerns will be clearance for the front wheel at full suspension travel, and on road handling. You will need to lift the rear to get the stance back to the proper weight distribution, which is also nicer since you gain some ground clearance. It would be a nice project and not too hard, but there is more involved than just swapping over the rim and spokes.
2003 DL1000
Too much other broken stuff to list
vanislejay is offline
post #4 of 25 Old 02-05-2019, 10:47 AM
You must do a lot of off pavement to want a 21 inch wheel, could always sell your XT and get an Africa Twin, KTM 1090 or Tiger 800.
Brockie, Motor7 and Hatchi like this.
post #5 of 25 Old 02-05-2019, 11:03 AM
The XT rims are DID. So sourcing a 21" wheel with correct spoke count should be no problem. Also finding correct spokes for that application should be no problem. Just find a bike with the same design front 21".
Unless you were born a Wizard, you won't be able to spoke the wheel yourself. So that becomes a problem in itself.
Once that is handled you will most certainly need to raise the front fender with an Adventuretech.biz fender kit. Or go directly to a high fender ( motocross/enduro mount ).
You will have bragging rights. It will also steer slow due to the geometry change. But that could be more stable off road.
You will still have a V Strom which doesn't match a true off road bike for those conditions.
realshelby is offline
post #6 of 25 Old 02-05-2019, 11:05 AM
Berksglh's Avatar
Location: I'm most alive when I'm in the north woods on my V2. So lets say Mountain Wi.
My fender raising kit on 2015 1000 with a brake line relocation will make the brake crossover cable come extreemly close to the radiator. Mine hit and put a ding in my radaitor when I bottomed the front. Its since been moved closer to stock. My fender is still hitting the crash bars cross over tube.
Not saying a 21 wont work, but fender clearance on the radiator and cross bar for the crash bars will be a major issue.
Sent from my RS988 using Tapatalk
DesertBike likes this.
Berksglh is offline
post #7 of 25 Old 02-05-2019, 12:22 PM
Buchanan's is probably a great place to start.
Buchanan Spoke and Rim, Inc. Terms and Conditions
Bentwee is online now
post #8 of 25 Old 02-05-2019, 09:26 PM
RichDesmond's Avatar
The brakes will be worse with the 21" rim, so take that into account.
Rich Desmond
RichDesmond is offline
post #9 of 25 Old 02-05-2019, 10:39 PM
I built a bicycle from pieces years ago. Spoked the wheels and got it right. It's just a matter of being careful and following instructions.
It's not rocket science and people did it for the last 100 years.
Spec and V-Harry like this.
notacop is online now
post #10 of 25 Old 02-06-2019, 03:30 AM Thread Starter
I love my strom and also love make mods on the motorcycle i have. The tiger 800 / f800gs are not the same price range and have others disadvantages (for the price of a strom with 2k-4k km you have a f800 or tiger with 50k-60k km + more expensive insurance...in my country ) I think a little offroad upgrade is just what i need on the vstrom.
i already have the shorter rear link / higher rear
OK it's nice to know that, it's a first thing to check !
This is my problem now, how i can find the right spokes ? angles, lenght...
Thanks for help and advices
DL1000/650 Front Wheel Removal MightyShep Maintenance How-to 53 03-18-2018 09:26 PM
Everything Related to Tires (Wheel removal, Repairs, DIY, ETC... Skinnifatkid Suspension and Tire Tech 36 10-28-2015 05:23 AM
DL650 lifting the front wheel off the floor with Centrestand Graeme Gould Maintenance How-to 12 08-17-2013 10:25 PM
Mud locks front wheel per_1999 DL650 and DL650A - 2004 to 2011 8 04-14-2008 10:20 PM
