Forks Upgrade - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-05-2019, 08:26 PM Thread Starter
Graphite Ghost's Avatar
Forks Upgrade
So after 40k Km of Aus ADV riding my XTA5 finally broke somewhat.
Front Fork seal blew, thanks Wombeyan Caves rd.
So I'm deliberating about pulling shocks out and taking to local shop.Or a specialist in these guys www.shocktreatment.com.au
At close to 1000 dollars I need some reassurance it's worth Upgrading
Graphite Ghost is offline
post #2 of 5 Old 01-05-2019, 08:32 PM Thread Starter
http://www.shocktreatment.com.au/
A better URL perhaps
These Gold Valves and variable compression springs sound very alluring.
All the Google feedback is absolutely glowing so I'm looking forward to reporting on outcome after Tuesday.
post #3 of 5 Old 01-06-2019, 08:49 AM
spike55_bmw's Avatar
Looks like you have a newer Strom than ours (2012-2016). Did you ask for advice over there?
spike55_bmw is offline
post #4 of 5 Old 01-06-2019, 10:59 AM
Motor7's Avatar
A grand for front shock revalve and re-build? That is really high, why not source the parts and do it yourself? Since you are in Australia, I would contact Jamie and see if he could put together a complete kit for you to DIY:
DMr Performance Suspension ? Performance Motorcycle Suspension and Chassis
Since he is close and reasonable I set him my forks and rear shock a couple of years ago for complete re-builds. That was 25K miles ago and I am still happy with his work...and it was night and day difference from the squishy oem set up. Don't forget about the rear shock too...it is just as important as the front for an overall perfect ride. It, however is not DIY rebuild-able and must be cut open and welded back together which is one of Jamie's specialties.
'15 DL650XT
Motor7 is offline
post #5 of 5 Old 01-10-2019, 04:28 AM
$1000 bucks.
It's a do it yourself thing unless that includes using their test track for fine tuning.
Was there an issue with the forks for the last 40km that you didn't like, if not whack seals in and ride.
Harry
PS I have use Shock treatmeant and they know suspension.
V-Harry is offline
Complete suspension upgrade for 2012 650 V-Strom drjoe Suspension and Tire Tech 3 05-06-2017 01:23 PM
Help, all owners - front forks, could you try loose in lower front fork,please? bedeker DL650A - 2012-2016 3 07-11-2014 07:32 AM
Suspension Upgrade Advice -- Suspension by Sasquatch incl. RT emulators in Forks Banks C General V-Strom Discussion 4 07-07-2012 01:10 PM
Fork upgrade - Initial thoughts and lessons learned Vellies DL650 and DL650A - 2004 to 2011 23 04-21-2012 11:00 AM
