Givi Airflow vs. Madstad - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 32 Old 11-29-2018, 12:42 AM Thread Starter
bendmac's Avatar
Greetings, fellow Stromers...
I'm 6'2 and have the stock Suzuki windscreen on my '13 Wee...the one with the built-in adjustable wind deflector at the top. For the most part, it does OK, but the buffeting can be a chore and I always wear earplugs as the wind noise is tiresome. (I have Richland Rick's mirror extenders installed already).
So...been doing research and have narrowed possible options down to either a Givi Airflow or a Madstad with their brackets and windscreen. I see plusses and minuses for both...I'm drawn to the Madstad a bit for its ability to tilt back and forth as well as up and down, as opposed to the Givi which just adjusts up and down. However, that lower piece on the Givi that has the "winglets" looks like it might provide some cleaner air.
So rather than poll the inmates on the benefits of either...are there folks out there who have tried BOTH and can offer some real world experience as to which worked better for you, and why?
Cheers!
Bendmac/Central Oregon
2013 Wee Adv...
EnduroGuardian bash plate/highway pegs/radiator guard;
AdventureTech LLC peg lowering mounts/mirror extenders/fork brace/shifter relocation kit, 2" extended front brake line;
Saddleman Gel-Channel Tech seat;
Barkbuster Storm hand guards;
Oxford heated grips;
Blue Seas 5025 6 circuit fuse block;
12v weatherproof power port;
Eastern Beaver headlight relay kit;
Cree LED lights;
Signal Dynamics voltage monitor;
Kisan signalMinder
PWD Stebel horn kit;
"Home grown" tool tube;
"Sasquatched" (Adventure Power Sports) rear shock
Madstad bracket and 22" screen
Roadstercycle SH775 R/R upgrade
SW-Motech bar risers
Mr. Ed's Moto custom seat
Superbright LED headlight bulbs and other bulbs converted to LED
bendmac is offline
post #2 of 32 Old 11-29-2018, 01:22 AM
Jeffro650's Avatar
Cheers!
On the subject of winglets, the combination of the Givi Airflow and the Augustus deflectors worked well for me. I had the windshield on first but did notice a bigger improvement once the deflectors were installed.
Jeffro650 is offline
post #3 of 32 Old 11-29-2018, 08:19 AM
I have a 2013 wee with a Givi Airflow and the Augustus deflectors and it made a big improvement. There is some still some air that comes up onto your chest and under your helmet but I find it comfortable up to 65 mph. I prefer secondary road travel topping up to about 65 mph for which this set up is perfect.
Jeffro650 likes this.
NewStrom
NewmarketStrom is online now
post #4 of 32 Old 11-29-2018, 09:28 AM
You will be disappointed in the Givi Airflow for higher speed operation. Great on back roads, around town. Once you crack 55 it goes downhill. Ok into the 60's if you don't have crosswinds or any traffic, but how often is that?
Get the Madstad bracket and one of their taller windshields. If in doubt, get the taller one! That is part of why the Madstad works, you can adjust height. But maybe more important is angle. Getting the top of the windshield closer to your helmet makes a lot of difference.
realshelby is online now
post #5 of 32 Old 11-29-2018, 10:29 AM
Macdoc's Avatar
Have not used both but cannot beleive anything can do a better job than the Madstad.....total adjustment and astonishing at speed. The new deflectors make it even better.
Mulewright likes this.
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is online now
post #6 of 32 Old 11-29-2018, 11:48 AM
Well that is interesting. The only drawback I have found to my bike (650) is that I am not comfortable at higher speeds on major highways due to the buffeting and wind noise. I had been thinking about a full fairing bike. Is the 22 inch Madstad the tall one?
NewStrom
post #7 of 32 Old 11-29-2018, 01:46 PM
Don't limit yourself to just the screens Madstad sells. Any screen that fits a 2004-2011 DL 1000 or DL 650 will fit the madstad bracket for the 2012-2016 DL 650. Aftermarket screens for the 2012-2016 DL 650 will not fit the Madstad bracket!!!
Always better to go too tall. In fact I would purposely go too tall and raise the mounting holes by drilling new ones. This helps remove some of the load on the weak cowl area of these 650's.
post #8 of 32 Old 11-29-2018, 02:23 PM
Bogfarth's Avatar
Madstad + CalSci = quiet bliss at 70mph. Add ear plugs and a Shoei helmet, you can hear yourself whisper (no joke) at 70mph.
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #9 of 32 Old 11-29-2018, 02:52 PM
Macdoc's Avatar
Yes that's good advice - I used a Givi ( not the Airflow ) on my 2010 650s plus the MadStad.
I'm using the Madstad solution with the air deflectors on the CB500x and it's a step up.
I'm not tall so can't advise but the Madstad and a decent sized screen goes a long way.
I could never get my CBF1000 screen working and even with a Madstad was unsuccessful - screen was just too narrow.
Best screen ever was my ST1000 with the OEM touring screen - so quiet at 150kph.
Wide and those cutouts really worked - of course the fairing is a big plus but the damn thing was too wide for my shortish legs and too hot in traffic in tropical Australia....but what a treat at speed.
senoje likes this.
post #10 of 32 Old 12-01-2018, 10:05 PM
jmf552's Avatar
I am very interested in this thread. I am in pretty much the same situation as the OP, but I am not all that experienced with motorcycle accessories. Two questions, if you please:
  1. I am not familiar with wind deflectors and I cannot find the Augustus ones for sale anywhere. Where can they be found and are there any alternatives to that brand?
  2. With the Mastad windscreen, I see they offer different tints. What do people here recommend?
Thanks!
Self-medicating two-wheel therapist...
jmf552 is offline
schuberth c3 pro / E1 with givi airflow matt650 Riding Proficiency 2 11-26-2016 09:17 PM
Givi Airflow and Rain Harry Dresden PI DL650A - 2012-2016 11 07-07-2014 08:18 AM
Where to buy Givi Airflow in Oz? Dave.A Australia-New Zealand 3 07-04-2014 02:55 AM
