Regulator/Rectifier? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 11-23-2018, 06:38 PM Thread Starter
senoje's Avatar
2013 with just past 15K on the "O", headed for the big city today about half way I noticed the LED volt meter bouncing around between 14.3-to 14.5...thought to myself that ain't good, never over 14.2 and solid. Had to stop to fuel and when I slowed down it felt like I had lost one of the plugs and felt a wee bit underpowed from the usual spunk. Lifted the seat and my EB fuse block relay was pretty warm and it smelled of some pretty hot wires. Turned it around and returned home, haven't had time to look see.... because of domestics needed done.
Your thoughts on what I might look for?
Warm regards, Ed
Ed Jones
VN Veteran 69 101st AB
STOC # 5950
AMA Life Member
2013 DL650A Adv. (Weester)
97 ST1100 (Shasa) SOLD
Just dropped in to see what condition my condition was in...... ;>)
senoje is offline
post #2 of 5 Old 11-23-2018, 06:52 PM
Bikehigh's Avatar
Thinking it's not the charging as system. No blown fuses? Burned wiring ought to blow a fuse or two.
Bikehigh is offline
post #3 of 5 Old 11-23-2018, 07:09 PM Thread Starter
senoje's Avatar
Just took a quick look all fuses seemed ok, I did start it up and there's no difference in head/run light flux either. Guess I had better go pull my Haynes out and do some reading tonight.
Ed Jones
STOC # 5950
AMA Life Member
senoje is offline
post #4 of 5 Old 11-23-2018, 08:25 PM
blaustrom's Avatar
Check battery terminals and main ground (and secondary ground) to have clean good contact and tight bolts.
Regulator failures are rather uncommon, so I would rule out other possibilities first. If you are suspicious of the EB fuse box, disconnect it temporarily and see if that cures it.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 5 Old 11-23-2018, 09:03 PM Thread Starter
senoje's Avatar
Thanks....noted and added to my list....
Ed Jones
STOC # 5950
AMA Life Member
senoje is offline
How to install a MOSFET or, preferably, a Series Regulator/Rectifier donstrom6 Maintenance How-to 120 04-13-2016 03:22 PM
Anybody Tried The 2014 Vee Regulator/Rectifier? PcolaDennis DL650A - 2012-2016 5 09-08-2014 01:19 PM
A Mosfet Regulator/Rectifier gsinpei Feedback to Suzuki 0 06-14-2011 05:20 AM
regulator/rectifier Glazier2000 DL650 and DL650A - 2004 to 2011 1 08-24-2009 11:38 AM
