Glee vibrating front panel - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 11-18-2018, 03:01 PM Thread Starter
zulu's Avatar
My glee had its headlights and screen changed a few weeks back (bloody van driver). Now at low revs something in front rattles. When I press the spedo with my hand while riding the noise stops, so obvious somethig is loose. Took to dealer, he checked, reopened, and tightened everything ( I was not present). But the rattle ia there. Any tips? Or anyone knows how to open the whole thing off?
zulu is offline
post #2 of 5 Old 11-18-2018, 03:09 PM
Missing push fasteners? Alignment is key.
Hatchi is offline
post #3 of 5 Old 11-18-2018, 03:41 PM Thread Starter
zulu's Avatar
Fasteners are in place. Dealer says he has opened and tightened everything again. Its obvious something is not set in place. I think I need to do it myself so any tips on opening the panel would be great!
zulu is offline
post #4 of 5 Old 11-19-2018, 02:16 AM
There are hidden fasteners. Best to get the manual I think.
https://advrider.com/f/threads/v-str...9&share_type=t
Hatchi is offline
post #5 of 5 Old 12-20-2018, 02:43 AM
dmfdmf's Avatar
I recently did some work on my L4 and pulled the cowling to get access. I noticed that there are four metal tabs on the radiator that insert into a mate on the black portion of the side cowling (#7 and #8 on the side cowling fiche fig.53). There are suppose to be rubber bumpers on these tabs but all of mine had fallen off (#6 on the radiator parts fiche fig.19). Luckily I found them in a cavity below inside the cowling. I put them back on but I attached them with some black gasket sealant to hold them in place. Maybe yours are MIA and causing vibration of the front panel.
Next Up: ?
dmfdmf is offline
Glee Front fender clearance with Shinko 712 Dharuma Suspension and Tire Tech 0 06-08-2015 03:00 PM
Front colored plastic panel removal? soldierguy DL650A - 2012-2016 6 08-06-2013 09:45 AM
U Nut Needed For Front Panel Replacement jurgenk DL650A - 2012-2016 3 07-31-2013 07:27 PM
