Hook popped out of my front sprocket cover - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By blaustrom
post #1 of 5 Old 11-08-2018, 06:47 PM Thread Starter
After getting my V up to its haunches in wet sand Sunday, I was cleaning it up and took off the front sprocket cover. A little hook popped out, and I'm not sure exactly where it belongs. I'm thinking it is secured by the lower front bolt for the sprocket cover on the inside, and its purpose is to maybe loop toward the back of the bike, around the wiring that attaches to the side-stand sensor, so the wiring doesn't wander .... it seems to fit there at that bolt, anyway, but that's just my best guess. Anyone else familiar with this doohicky and where it goes?
It's a 2012 DL 650.
Thanks for any info...
spthomas1 is offline
post #2 of 5 Old 11-08-2018, 06:51 PM
blaustrom's Avatar
Its the holder for the kickstand lockout switch cable. Held by the lower left bolt of the cover, if I remember right. On the outside!!
Curl it around the cable so next time it won't fall down, just slide down the cable.
Big B likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 5 Old 11-08-2018, 06:59 PM Thread Starter
Thank you for the response, Blaustrom. Hope you can some more riding in before the snows come.
On the outside? As in, secured between the head of the bolt and the surface of the cover? And curling around inside where the wiring is?
Hmmm... OK
post #4 of 5 Old 11-08-2018, 07:20 PM
blaustrom's Avatar
OK, I assume the 2012 is similar to the older ones. There should be a cable going to the kickstand lockout switch outside the cover. You have such an electrical cable?
I don't know what electrical cable you have inside the sprocket cover?
On the outside? As in, secured between the head of the bolt and the surface of the cover? YES
Most likely no more riding, first snow forecast for the weekend, hopefully it will come and go, we still need to rake some leaves.
Blau2 2014 DL1000A
post #5 of 5 Old 11-08-2018, 10:33 PM Thread Starter
Thank you for the input, I appreciate it -- happy riding, raking, and snow-man making...
Front sprocket - don't make my mistake Thighrod General V-Strom Discussion 29 10-24-2017 10:36 PM
Front sprocket chain cover Kruzzin5 Maintenance, Tech and Products. 19 03-19-2015 05:04 PM
removing front sprocket cover on 2009 wee robfilms DL650 and DL650A - 2004 to 2011 3 10-21-2014 11:53 AM
Front Sprocket Wear question eegah V-Strom Service and Maintenance Questions and Discussions 9 06-29-2010 08:30 PM
