Kaoki throttle lock for - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 11-05-2018, 12:42 PM Thread Starter
Location: Now living in Milton, Delaware and in the winter near Sarasota, Florida
2018Been looking for the Kaoka throttle lock for the 2018 vstrom 650 abs witht the oem handguards.Seems as tho no one has them and no one knows when they are coming in. Does anyone out there have any solution. Thanks
Ride till you tire.... Then camp under the stars!
manofsteel1 is offline
post #2 of 6 Old 11-05-2018, 01:58 PM
Bikehigh's Avatar
I know a rider who uses a nice think o-ring as a throttle lock. He's obviously not the only one.
I wouldn't hold out hope for a Kaoko solution. It does't seem compatible, and they're not gonna engineer a solution just for our bikes.
8M4991 Caterpillar Yellow Silicone O-Ring https://www.amazon.com/dp/B00BQ1BL46..._tgj4BbVP9C237
Bikehigh is offline
post #3 of 6 Old 11-05-2018, 03:21 PM
Hmm
Hmm's Avatar
Check into an Atlas throttle lock. Very easy installation. Adjustable friction and easy to use push button on/off instead of winding your throttle back and grabbing a friction ring at the same time. Also, made in the good old USA. I rode with mine for the first time a couple of days ago and once I get it adjusted properly I think that I will like it a lot.
Bill
I been down around Houston Texas where the sun shines most of the time.
2008 Wee current
2014 Spyder RT LTD current
Past - Yamaha 850, Honda Nighthawk 700, Honda GL1200, Yamaha FJ1200, Suzuki Bandit 1200, Honda GL1800
Hmm is offline
post #4 of 6 Old 11-06-2018, 11:16 PM
I found Kaoka tricky too fiddly for my clumsy fingers. I got a Vista for $40. Easy push button on-off and compatible with hand guards as it fits in next to the switch block. A bit of McGyvering required to fit it but it works great.
Chipwidget is offline
post #5 of 6 Old 11-08-2018, 02:47 PM
RevD's Avatar
I’ll second the Atlas. Love mine. I’ve used it for about 20,000 kms and don’t have a single negative thing to say about it. I’ll buy another if my next bike doesn’t have cruise control.
RevD is offline
post #6 of 6 Old 11-10-2018, 07:59 AM Thread Starter
Have a Kaok on me 2015 and would Not give it up for anything. Now to put one on me wifeys and can not be found. Kaoka makes one just for the 2018 with the OEM handguards but they seem to be sold out every where. Tha alone seems to me to be the throttle lock of choice. Even AdventureTech is sold out! Wow
Manual throttle lock recommendations Mastery General V-Strom Discussion 35 05-13-2019 08:26 AM
Throttle Lock that works with Barkbusters dwayneh DL1000A - 2017+ 21 12-13-2017 09:51 AM
Omnicruise Throttle lock for V2 08Wee DL1000A - 2014-2016 2 07-14-2015 06:26 PM
Oxford Heated Grips + Kaoko Throttle Lock + Hand Guards ??? jtice DL650 and DL650A - 2004 to 2011 5 04-11-2015 10:01 PM
Kaoko Throttle Lock Cruise Control was Before I Pull The Credit Card Out .... Harry Dresden PI DL650A - 2012-2016 23 03-31-2014 04:28 PM
