Where does this thing go? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By locoblanco
  • 1 Post By V2man
post #1 of 6 Old 10-22-2018, 01:27 PM Thread Starter
Just cleaning my bike up after a long tour, and I had this thing just come out loosely in my hand. Where is the hose barb this thing attaches to or is it just a breather?
mister_dog is offline
post #2 of 6 Old 10-22-2018, 09:36 PM
Looks to me like a breather. Trying to remember from my old wee, but I believe it routes along the edge of the side engine case. There should be a tab that holds in in place
Houstrom46* is online now
post #3 of 6 Old 10-22-2018, 10:42 PM
locoblanco's Avatar
Tucks in behind the hoses next to the filter. It's the breather off the water pump.
V-Harry likes this.
locoblanco is offline
post #4 of 6 Old 10-22-2018, 11:48 PM
V2man's Avatar
Looks like the tell tale hose for the Impeller.
If the mechanical seal at the rear of the Impeller is damaged coolant will leak into a chamber at the rear of the Impeller & come out of that pipe into the bash plate.
It prevents the seal to the motor being put under pressure and possible coolant getting past into the motor.
Cheers
V-Harry likes this.
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #5 of 6 Old 10-23-2018, 03:12 PM Thread Starter
Thanks for the prompt responses folks.
I thought it was just a breather, because it has no clamp or barb marking / stretching on it, but I obviously wanted to make sure, as it is clearly related to the coolant. I couldn't find a barb, but could find a place where it tucked in behind the oil filter.
However, I also found a chunk of broken metal that had been the round bottom of a mount at the bottom of the bike and was like, "whoa now, what is this all." and ran right along to ask the grownups what was happening. =)
The broken mount arc was determined to be from a footpeg (NEXT TIME DON'T RIDE DIRT LIKE A WILD MONKEY) and I wanted new footpegs anyway.
post #6 of 6 Old 10-29-2018, 09:47 AM
D.T.'s Avatar
Suzuki SV's have the leak tube also. It's for the impending death of your shaft seal for coolant.
Not really an easy DIY project either, kinda a PITA.
D.T. is offline
Weird thing happened at the shop today maximilian Maintenance, Tech and Products. 4 02-22-2012 09:22 PM
One less thing to lust after. Donunder Australia-New Zealand 21 02-22-2012 03:13 PM
Strange thing happened today..... joedaddy DL650 and DL650A - 2004 to 2011 6 07-07-2009 06:44 PM
