No headlights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By t-dubc
post #1 of 4 Old 10-05-2018, 07:37 PM Thread Starter
No headlights
my 2012 V-Strom 650 has no headlights .bike starts fine blinkers work fine no high beams no low beams I can't find a bad fuse not sure where to go from here. Bulbs are not burnt out.
Sent from my moto x4 using Tapatalk
t-dubc is offline
post #2 of 4 Old 10-05-2018, 08:31 PM
chicago's Avatar
This is a fairly regular complaint. Type 'headlight problems' in the google search box and you'll see you have plenty of company. The most common issue is the starter/headlight cut out switch. Here is a sample of the threads that will turn up.....
https://www.stromtrooper.com/general...on-issues.html
a headlight relay can prevent the problem once it's repaired.
14 tooth for me
chicago is offline
post #3 of 4 Old 10-05-2018, 09:35 PM
You may need an Eastern Beaver headlight relay. Ridiculously easy to install and it works!! Fixed the headlight problem on my 2012 DL1K.
https://easternbeaver.com/Main/Bike_...om/vstrom.html
remoandiris is offline
post #4 of 4 Old 10-07-2018, 10:44 PM Thread Starter
Problem solved as you all said completely correct
Big B likes this.
t-dubc is offline
K5 Wee Headlights - none of the usual suspects sgifford V-Strom Service and Maintenance Questions and Discussions 7 05-23-2015 12:21 PM
Headlights wiring issue theDraco DL1000 from 2002-2012 8 07-10-2014 07:48 PM
headlights, ignition switch and choosing relays (Eastern Beaver or DDM HID kit) the schwartz V-Strom Service and Maintenance Questions and Discussions 10 09-24-2013 08:54 AM
Headlights Malfunctioning tberger53 DL650 and DL650A - 2004 to 2011 4 08-09-2012 09:20 PM
3M film on headlights..... CollingsBob V-Strom Service and Maintenance Questions and Discussions 4 06-04-2011 07:40 AM
