Coolant FLUSH Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 11 Old 09-26-2018, 09:07 PM Thread Starter
M3B
M3B's Avatar
I'm in the middle of a coolant flush on my 2013 dl650 a. I'm in the process of bleeding the air from the system. I filled up the radiator with the indicated amount of fluid and now it's time to run the engine as part of the bleeding process. I know this is a real technical and probably noobish question, however, when I run the engine, should I put the cap back on the radiator or leave it off?
M3B is offline
post #2 of 11 Old 09-26-2018, 09:30 PM
Leave the cap off while running the engine to bleed the system. Rock the bike until bleeding stops, filling the radiator to the inlet as you go. Once air is bled then replace radiator cap. Then you can turn the bike off, warm it back up and cool it down a few times, then fill the reservoir.
Big B and V-Harry like this.
Dodobo is offline
post #3 of 11 Old 09-26-2018, 09:55 PM Thread Starter
M3B
M3B's Avatar
Thank You! I can't wait to get the bike back on the road. Time is running out up here in the Northeast....
brutalguyracing likes this.
M3B is offline
post #4 of 11 Old 09-27-2018, 04:47 AM
teamrocket55's Avatar
Did everything turn out ok for you?
You are smart to stay ahead of cooling system problems via preventative maintenance.
V-Harry likes this.
teamrocket55 is offline
post #5 of 11 Old 09-27-2018, 06:27 AM Thread Starter
M3B
M3B's Avatar
Hey Team)) Thanks. The PO kept on top of things. There was a coolant change w super long life about three + years ago. I've put a ton of miles on and figured I should have at it))
M3B is offline
post #6 of 11 Old 09-27-2018, 06:29 AM Thread Starter
M3B
M3B's Avatar
...oh... and I plan to finish up tonight or tomorrow... work is getting in the way
M3B is offline
post #7 of 11 Old 10-02-2018, 03:51 PM
VstromGrin's Avatar
What mileage is on your 650 now? suppose it's a good idea to change the coolant every so often.
the shock will also need replacing at some point too.
2013 SUZUKI DL650 AL2
VstromGrin is offline
post #8 of 11 Old 10-03-2018, 09:05 PM Thread Starter
M3B
M3B's Avatar
I think my mileage is somewhere between 14 and 15000 miles. I still haven't finished the job. Work keeps getting in the way. I guess it's just a busy time of year. Also, I couldn't get the radiator to take the full 1700 ml replacement fluid. As a result I wanted to ride it around a bit before replacing the side panels just to make sure that I've bled all the air out of it. I suspect that my efforts to flush it we're not entirely successful, and that I left about 300 mL of old coolant behind.
M3B is offline
post #9 of 11 Old 10-04-2018, 02:18 PM
larolco's Avatar
Put the bike on the side stand while bleeding, not the centre stand (if you have one).
Keeps air from getting trapped.
VstromGrin and Railrocker like this.
DRZ400SK17
larolco is offline
post #10 of 11 Old 10-07-2018, 01:10 AM
Dny209's Avatar
How often is it recommended to change the coolant?
2012 Dl650
Dny209 is offline
coolant flush question.. viclava DL1000 from 2002-2012 2 05-22-2018 10:10 PM
Fork oil and coolant question Demorative DL650 and DL650A - 2004 to 2011 9 01-22-2018 10:45 AM
Coolant Temperature Meter Question mntrailhiker DL650A - 2012-2016 7 05-12-2017 11:32 PM
Warning on mixing coolant types Thunderdownunder General V-Strom Discussion 0 08-06-2014 08:45 PM
coolant question shrike DL650 and DL650A - 2004 to 2011 9 04-27-2010 02:49 PM
