Technical question (millimeters and stuff!) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 14 Old 09-25-2018, 09:04 PM Thread Starter
KakoHarris's Avatar
i'm trying to calculate the distance between 2 screw holes but i can't.
could you help me guys? it's where the center stand goes... i make a center stand by myself a couple weeks but the distance between has been wrong and i had to fix it
my idea it's make it without issues
could you tell me the distance please? (in MM pls!!!!)
KakoHarris is offline
post #2 of 14 Old 09-25-2018, 09:10 PM
p38arover's Avatar
Do you have a pair of engineer's dividers? If so, put one point on the centre of the bolt and the other on the centre of the hex screw. Lock the dividers then use a rule to measure the distance between the divider tips.
I no longer have a Strom otherwise I'd go and measure mine.
I don't know if you use the same terms for tools as us but these are what we call "dividers".
VSrider likes this.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is online now
post #3 of 14 Old 09-25-2018, 10:53 PM Thread Starter
KakoHarris's Avatar
thanks p38 but the size of the tool on the needle point wasn't the same size of the screw hole... so maybe i will takes the wrong size
post #4 of 14 Old 09-26-2018, 09:35 AM
Also, the distance is probably a whole number of millimeters. Engineers aren't going to use a fractional distance for something as crude as the center stand. For example, the distance might be 155 mm instead of 155.734 mm.
2013 DL650A, OEM centerstand, Powerlet outlet, Parabellum windshield with X-screen deflector.
scritch is offline
post #5 of 14 Old 09-26-2018, 10:15 AM
Just asking..but couldnt you make a template off the motorcycle and transfer it to your center stand mock-up?
MAZ4ME is offline
post #6 of 14 Old 09-26-2018, 11:23 AM Thread Starter
KakoHarris's Avatar
i already been try it that idea but the distance between doesn't be exact
post #7 of 14 Old 09-26-2018, 01:17 PM
Measured on my '16 650 to be exactly 70mm between the center of the two bolts. Hope that works for you and good luck!
Dodobo is offline
post #8 of 14 Old 09-26-2018, 01:39 PM Thread Starter
KakoHarris's Avatar
THANKS A LOT DOBODO!!!
could you take a pic too see if the model changes something trought the years?
post #9 of 14 Old 09-26-2018, 03:44 PM
PerazziMx14's Avatar
Its hard for me to fathom being able to fabricate a homemade center stand but cannot figure out how to measure the distance between the centerline of 2 fasteners.
2013VEE650 likes this.
PerazziMx14 is offline
post #10 of 14 Old 09-26-2018, 05:03 PM
Ouch!!! That left a mark.
kfh000 is online now
Tire Question? But not which tire question VStromThom DL1000 from 2002-2012 11 03-23-2014 10:51 AM
wiring a ground question chetc General V-Strom Discussion 7 11-16-2012 05:38 PM
DL1000 Chain Question (ordering question) shawnubis DL1000 from 2002-2012 5 11-16-2012 09:31 AM
Dirt, gravel and mud question TheWall DL650 and DL650A - 2004 to 2011 19 06-02-2012 10:11 AM
Boot Question - Revisited apexeric General V-Strom Discussion 31 07-07-2008 12:07 AM
