Oxford Heated Grip Install Perfection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 19 Old 09-23-2018, 07:09 PM Thread Starter
Hello,
On a 2012+ and when installing the oxford heated grips, did anyone try removing the plastic on the throttle tube nearest the start button? I have attached pictures to demonstrate. It seems that if the plastic were removed, then the grip could slide further onto the throttle tube. The second picture shows what it looks like with the grip slid over as far as possible and I'd say it bugs me a bit. The third pictures shows there is a bit of grip left hanging over the handlebar with the grip fully slid to the left. These are the touring version of the oxfords and are almost perfect length.
Thoughts? Should I try cutting that plastic off?
Toadster is online now
post #2 of 19 Old 09-23-2018, 07:16 PM
Jeffro650's Avatar
Yes I did remove that plastic on my throttle tube when using touring grips. I think there is a thread in the forum discussing that as well.
Jeffro650 is online now
post #3 of 19 Old 09-23-2018, 08:14 PM
Brockie's Avatar
That plastic lip on the inside of your throttle tube is a simple design element to prevent the grip from ever sliding across and binding on your switch block.
Sure, you can remove it - but should you? Can you guarantee that sometime in the future your grip will not slide onto the throttle tube? It is there for a reason. Your decision.
Brockie is online now
post #4 of 19 Old 09-23-2018, 08:24 PM Thread Starter
I went ahead and removed it. I plan on supergluing the heated grip to the throttle tube. That'll hopefully prevent the grip from sliding into the start block.
NeverSatisfied likes this.
post #5 of 19 Old 09-23-2018, 09:45 PM
MrF
MrF's Avatar
I removed mine.
There are two lips there. The larger one with the triangular cross section holds the factory grip in place and keeps it from sliding either direction. Leave the smaller, left most lip like in Jeffro's photo and you won't have to worry about the scenario that Brockie described. That's enough of a lip to keep the oxfords from sliding left.
rodentface likes this.
2016 V-Strom 650
MrF is offline
post #6 of 19 Old 09-24-2018, 07:26 AM
bighammer's Avatar
The ~$16 heated grips I bought on Amazon had their own plastic tube. Install was a just a matter of opening the clam shell and removing cables and installing new throttle tube.
2018 Flee-Strom 1000XT
bighammer is offline
post #7 of 19 Old 09-24-2018, 01:02 PM
what's their name?
In my previous 2010 I installed the oxford heated grips (touring ones) leaving intact the throttle plastic grip and cutting the heated grip a bit on the right side (Oxford allows that to match different grip sizes). You need to be careful to allow some space between the heated grip and the weights on the handlebar sides (especially for the right one, the left one doesn't matter too much).
fear_factory84 is offline
post #8 of 19 Old 09-24-2018, 02:09 PM
bighammer's Avatar
Originally Posted by fear_factory84 View Post
what's their name?
Here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #9 of 19 Old 09-25-2018, 08:51 AM
Judging by the instructions I can tell this is a quality product.
"Balance ,please take it as well as balancing the installing position, fasten silk don't squeeze his hand .
as the balance of iron can not adjust the installing position, in the balance of iron can not adjust the installing position ,in the balance with the iron hand between the washers of and excessive press hand will cause damage the abnormal"
Big B, fear_factory84 and MrF like this.
2013 DL650A, OEM centerstand, Powerlet outlet, Parabellum windshield with X-screen deflector.
scritch is offline
post #10 of 19 Old 09-25-2018, 09:15 AM
Chinese to English machine translation works in this way... you need to see how hilarious is when they translate from Chinese to English and then to Italian LOL!
Heated grip install JimSTer DL650 and DL650A - 2004 to 2011 8 01-20-2017 10:57 PM
heated grip plug Kenter Maintenance, Tech and Products. 7 10-12-2016 04:25 PM
Bikemaster heated grip install using OEM Connector bhavinjo DL650A - 2012-2016 3 07-04-2014 09:14 PM
OEM Heated Grip Connector Not The Best Solution? Why? DGrav DL650A - 2012-2016 9 09-29-2013 08:28 AM
