New to Me 2012 650A - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 09-19-2018, 03:10 PM Thread Starter
triman11427's Avatar
New to Me 2012 650A
I'm about to take ownership of a 2012 DL650A with 29,000 miles on it. I figure 6-7 year old bike ridden about 6-7000 miles per year isn't a big deal with these bikes. I'm buying from a dealer so there aren't any records aside from speaking with the PO over the phone. Stator recall and valves were checked at 21,000 miles. Bike looks clean and comes with all the farkles I would do along with an Ohlins shock. Lowered pegs, Top box in addition to the Suzuki cases, gel seat, ROX risers, heated grips. I'm told we're similar in stature but the bike is set up for a 225lbs. I weigh 190so I'm sure some suspension adjustment is needed. Here in NY you can't necessarily get a test ride but I do have a 30 day warranty. I've owned a 2011 650 and a 2014 V2 so I'm familiar with the Vstrom. I'm having the dealership do an oil change but thats all they're offering. Fluid in brake master cylinder looks clear and the bike started right up and sounded great. No ticking, tapping, or anything audible. I'm replacing rear tire with a Pilot 4 to match the front Pilot 4 which looks fine. Anything I'm missing before committing to buy?
triman11427 is offline
post #2 of 14 Old 09-19-2018, 03:22 PM
Jeffro650's Avatar
Sounds like itís been well cared for. As you know the Vstrom is a very reliable bike. Miles are not a concern as long as it has been maintained. I have a 2012 as well. Only thing I can suggest is check to see if a longer front brake line was installed when the risers were added. I know you canít put 2Ē risers on without causing issues. Good luck and ride safe!
Jeffro650 is offline
post #3 of 14 Old 09-19-2018, 10:40 PM
TAZ650's Avatar
Buy it...Its a Vstrom!
TAZ650 is offline
post #4 of 14 Old 09-19-2018, 11:44 PM
Mucksavage's Avatar
Seems like the time to buy a '12! I did last month
'12 Glee, Metallic Fox Orange, '98 DR350, CMA #183680
Mucksavage is offline
post #5 of 14 Old 09-20-2018, 01:06 AM
KSM
KSM's Avatar
I hope it's white on black! (But I guess black is ok, too.)
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #6 of 14 Old 09-20-2018, 02:01 AM
me too (got black this time)) replacing my 2013 (white one))
Rick123 is offline
post #7 of 14 Old 09-20-2018, 07:24 AM Thread Starter
Alas, itís the black one. Anyone have any ideas how to spruce up the black plastic pieces. Looking a bit tired.
post #8 of 14 Old 09-20-2018, 09:31 AM
VSrider's Avatar
This works well if you're referring to the unpainted plastics. They can fade if the bike is parked outside. https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
VSrider is offline
post #9 of 14 Old 09-20-2018, 03:44 PM Thread Starter
Not looking to paint the plastics, just looking for an excellent cleaning/preservative to refresh 7 years of riding.
post #10 of 14 Old 09-20-2018, 07:30 PM
shu
shu's Avatar
Although this bike needs very little maintenance, it does need to be cared for.
That the valve check was done is a very good sign. I know many people feel that since the valves very often don't need any adjustment for tens of thousands of miles, it is perfectly okay to skip this check.
And actually, that has been true for my bike, (valves checked at 15,000 and at 30,000 miles with no adjustments needed.) But, I'll keep checking them and I personally wouldn't buy a used bike that had never had the valve check done.
................shu
shu is offline
Shad/other cases and 2012 650A? Outbackwack DL650A - 2012-2016 13 11-06-2014 03:09 PM
Factory Gel Seat 2012 Vstrom 650A RickyBilly DL650A - 2012-2016 4 09-09-2014 09:31 PM
