Clutch adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 18 Old 09-17-2018, 05:42 AM Thread Starter
Clutch adjustment
Hi guys need to adjust my clutch lever as its too far out qhen reaching for it. What i am wanting to know is the adjuster part way down the clutch cable has a lock nut and a long hex shaft onto a long thread. Do i wind the the hex down the the thread towards the floor clockwise or wind it up away from the floor anticlockwise. Hope i explained what I'm trying to do ok.
willwoms is offline
post #2 of 18 Old 09-17-2018, 07:59 AM
locoblanco's Avatar
That adjustment controls cable free play. If you have too little free play it's like "riding" the clutch, too much free play and the clutch won't fully disengage. The reach to the lever, unlike the brake lever, is not adjustable. There are aftermarket options, but be careful as some of them don't properly mate with the clutch safety switch when starting.
locoblanco is offline
post #3 of 18 Old 09-17-2018, 09:40 AM
Brockie's Avatar
Adjusting the clutch cable will affect where the clutch engages/disengages but have no effect on the reach for the clutch lever - only an adjustable lever like these can help with that.
https://www.ebay.com/itm/3D-For-Suzu...r=410991086056
https://www.ebay.com/itm/Motorcycle-...r=431986726418
Brockie is offline
post #4 of 18 Old 09-17-2018, 12:35 PM Thread Starter
That's what I'm wanting to do is adjust the bite point of the clutch so it engages sooner. Just not sure which way to turn the adjuster.
willwoms is offline
post #5 of 18 Old 09-17-2018, 12:36 PM Thread Starter
I don't think I explained it to well. Sorry guys.
willwoms is offline
post #6 of 18 Old 09-17-2018, 02:10 PM
VstromGrin's Avatar
I am wondering the same thing, not sure which way to turn the adjuster part way down the cable, or the one right at the point where the cable meets the lever with the big wheel adjuster on it, my gearshift isn't as smooth as it used to be.
2013 SUZUKI DL650 AL2
VstromGrin is offline
post #7 of 18 Old 09-17-2018, 02:43 PM
Rolex's Avatar
Making the outer cable "longer" will put the engagement point further away from the grip and making it "shorter" will put it closer to the grip but the lower adjuster is the true adjustment point.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 18 Old 09-17-2018, 04:50 PM
locoblanco's Avatar
The spec is 10-15 mm of movement at the end of the lever, which way to turn the adjuster depends on whether there is too much or too little play. Once you start turning you will see right away if it's getting tighter or looser. Either adjuster can be used. Best to turn each one a little than only one of them a lot.
Big B likes this.
post #9 of 18 Old 09-17-2018, 07:42 PM
Brockie's Avatar
How many miles are on your Weestrom willwoms? When I was having difficulty making smooth shifts I found the cure to be not adjusting the cable but adjusting the clutch itself - however for you that will entail draining the oil and removing the clutch cover.
BornToRide likes this.
Brockie is offline
post #10 of 18 Old 09-18-2018, 09:31 AM
I always go with the tried and true "try it and see." Went in the opposite intended direction? Double back!
That being said.... I've noticed lately while doing test rides that a LOT of bikes seem to have a lot of play before the clutch engages. Am I more abnormal in liking it to catch earlier?
Ah well... in the end, it's just getting used to it, really.
Rehclip is offline
Clutch Adjustment Help SquidWilly V-Strom Service and Maintenance Questions and Discussions 29 09-16-2018 12:24 AM
New clutch or adjustment?? 2wheelfun V-Strom Service and Maintenance Questions and Discussions 2 07-10-2015 04:37 PM
Attempting to do a clutch adjustment... but lock nut is too tight arooni Maintenance, Tech and Products. 2 09-11-2012 07:25 PM
Lower Clutch Adjustment ianbh DL650 and DL650A - 2004 to 2011 3 08-19-2011 10:14 PM
Clutch Adjustment StromFlyer DL650 and DL650A - 2004 to 2011 8 12-27-2007 04:32 PM
