Hazard signals not working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 09-15-2018, 09:56 AM Thread Starter
bajakirch's Avatar
I noticed the other day my hazard signals don't appear to be working. Turn signals are OK, so I'm thinking something with the switch.
Any common things I should look for?
bajakirch is offline
post #2 of 5 Old 09-15-2018, 10:14 AM
If the turn signals work but the hazards don't, then I would start with the contacts within the handlebar cluster. That's the only place where the hazards and turn signals don't share the same wiring/relays/light bulbs and whatnot. (Or do they diverge as well in the contact switch, to allow you to use the hazards in Park?)
Has the bike been exposed to a lot of rain lately? The hazards switch is a lot more exposed than the turn signal switch.
BackPacker is offline
post #3 of 5 Old 09-15-2018, 10:14 AM
Brockie's Avatar
I'd start inside the LH switch block, checking the wires and contacts in there.
Brockie is online now
post #4 of 5 Old 09-16-2018, 09:44 AM Thread Starter
bajakirch's Avatar
In fact, yes. I ended up caught up in a major storm about a month ago and rode in downpour conditions for about 2 hours.
I'll check the contacts.
post #5 of 5 Old 09-16-2018, 05:58 PM
Mine sometimes does this. I've found toggling tge switch a few tines then riding with the hazards turned on eventually brings them back to life. I've previously taken the left hand switch apart expecting corrosion or something but found nothing in there (still sprayed contact cleaner on there whilst I had it apart).
uk-vstrom is offline
Replacement turn signals for 1st-gen Vee? bwringer DL1000 from 2002-2012 11 09-20-2017 07:06 PM
Bestem T-Box lighting. Turn and brake signals... FredBGG General V-Strom Discussion 5 02-02-2015 11:32 AM
Turn signals not working? domromer General V-Strom Discussion 10 07-11-2012 09:00 PM
Weak turn signals on the V-Strom in daylight Mercenary General V-Strom Discussion 18 07-16-2009 07:57 PM
Protected front turn signals barker Maintenance, Tech and Products. 14 07-06-2009 09:31 PM
