Bolt spec needed handle bar weight bolt - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By spike55_bmw
post #1 of 8 Old 08-20-2018, 05:42 PM Thread Starter
Hi
I need to put on a set of bark busters generic on my wee but what is the spec of the bolt that holds the balancing weights on the handlebars?
I need the length , width , thread spec 1 or 1.5 all in mm thanks I know mine are phillips head pan type
Suzuki 650 2014 weestorm
Geo650 is offline
post #2 of 8 Old 08-20-2018, 07:06 PM
locoblanco's Avatar
Part # 09127-06018. 6x110mm according to the parts fiche. Doesn't give the pitch but usually 1.0 for a 6mm bolt.
BTW, it's not Phillips, it's JIS, (Japanese industrial standard), close but not exactly the same. A Phillips screwdriver could tear up the head. Use the screwdriver from the factory tool kit, it's the proper fit.
locoblanco is offline
post #3 of 8 Old 08-20-2018, 08:56 PM
Brockie's Avatar
Why do you need a bar end weight bolt? Barkbusters come with all the fittings necessary. To fit them you will need to remove the bar end weights but be very careful to not completely remove the bolt which holds all of the parts together. Just loosen the bolt, and wiggle and pull on the weight. it will eventually come out as a complete unit.
Brockie is offline
post #4 of 8 Old 08-21-2018, 06:40 AM
spike55_bmw's Avatar
I agree - Why? When I switched the the BarkBusters, I bagged the OEM bar end weights and hardware in a ZipLok bag for save keeping for the next owner 20 yrs from now.
BTW, I'm assuming that you might be doing some off-road work if you're looking at BarkBusters. From personal experience (KLR650), you want to have the ends of your handlebars as "clean" as possible went weaving through vegetation. You will quickly be on the ground looking up if the end of the handlebar catches on anything for a second or two at any speed over 3-5 mph.
If you're concerned about vibration, I pulled Grab-On foam covers over my Oxford heated grips. Addressed three issues: 1.) Heated grips; 2.) Vibration dampening; 3.) Increase the size of the grip diameter - OEM feels tiny too me and my hands aren't comfortable curled around a tiny grip for too long.
brutalguyracing likes this.
spike55_bmw is offline
post #5 of 8 Old 08-21-2018, 07:18 AM
I believe bar end bolt between the DL1000 and DL650 is different. The DL1000 is longer.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #6 of 8 Old 12-02-2018, 03:47 AM
I have a 2009 Wee and bent my bar end bolt on a drop. Anyone have a source for a new one?
davidprej is offline
post #7 of 8 Old 12-02-2018, 07:23 AM
locoblanco's Avatar
Ace hardware.
post #8 of 8 Old 12-05-2018, 10:58 AM
I bought a new bolt from Suzuki for bar end after i got knocked off mine. It was only a few dollars. When i put hand guards on they came with new bolts as they are shorter. I bought the genuine Suzuki ones they were the best for price.
willwoms is offline
