wonky idle 2012 650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By uk-vstrom
post #1 of 8 Old 07-30-2018, 08:00 PM Thread Starter
Majster81's Avatar
wonky idle 2012 650
Guys and gals,
So 2012 650 V strom 30K on it. I noticed that my idle drops haphazardly to around 1K RPM. I am riding and all is fine. Stop at the light and 75% of the time the idle needle is pointing just slightly above 1K. Could it be TPS?
[URL=https://www.fuelly.com/motorcycle/suzuki/dl650a_v-strom_abs_adventure/2012/Voigtlander912/302097][IMG]https://badges.fuelly.com/images/sig-us/302097.png[/IMG][/URL]
Majster81 is offline
post #2 of 8 Old 07-30-2018, 08:03 PM
dmfdmf's Avatar
Sounds right to me. Once it is warmed up, does it ever stall coming to a stop? That was the main symptom when my TPS went bad.
Next Up: ?
dmfdmf is offline
post #3 of 8 Old 07-30-2018, 08:11 PM Thread Starter
Majster81's Avatar
It seems like it's wanting to but it doesnt stall. How does one go about replacing one of these sensors?
post #4 of 8 Old 07-30-2018, 08:26 PM
dmfdmf's Avatar
@Majster81
I did a quick search of the site for "replace TPS" and found this, there may be other threads but this one looks pretty good. You'll need security Torx bit but other than that it is pretty straight forward if you wrench.
TPS Replacement
Next Up: ?
dmfdmf is offline
post #5 of 8 Old 07-31-2018, 05:55 PM
Motor7's Avatar
Have you replaced the clutch lever with aftermarket?
'15 DL650XT
Motor7 is offline
post #6 of 8 Old 07-31-2018, 07:28 PM Thread Starter
Majster81's Avatar
No I still got original levers.
post #7 of 8 Old 08-01-2018, 03:43 AM
You can adjust the TPS to correct the idle speed if needed. You need to put it in dealer mode, let the engine warm up then adjust (move) the TPS if it's out.
The Torx is a T25 security one (it has a hole in the tip) and the TPS only needs the slightest adjustment.
If you're in dealer mode, you get C00 with a line at the side _C00 is too low, -C00 is spot on and C00 with the line at the top is too high.
IIRC the advice Greywolf gave me, idle should be centred around 1200rpm with it moving to the top just over 2000rpm. [The adjustment below received GW's approval which was good enough for me ]
This was mine before - You can see it was out
https://youtu.be/u0ZyKUZn9WI
After
https://youtu.be/zajbGiMBXHQ
Majster81 and brutalguyracing like this.
uk-vstrom is offline
post #8 of 8 Old 08-18-2018, 12:03 PM Thread Starter
Majster81's Avatar
so I went ahead and replaced TPS. at fully warmed up bike the idle is stable and - is center, it raises to the top line when it is passed 2K. It sometimes goes back to middle if I let off the throttle a bit. That is when riding. When stopped in Neutral the dash line does not come up to the top until something like 3K
