2015 DL650A Front Sprocket Removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 07-18-2018, 10:25 PM Thread Starter
Hey everyone! I’m inexperienced when it comes to mechanics and want to learn so I’m attempting some work on my bike. I’ve ran into the front sprocket and where I thought you’d simply use a hex key to remove the first portion, it isn’t working. Do I need a socket or can someone explain the black portion that looks like it’s filling the hex key/Allen wrench hole? Thanks in advance.
File Type: jpg C0C5B07B-0E2E-4136-90A1-3D01612F7EB3_1531967105378.jpg (358.1 KB, 31 views)
Kieuhl is offline
post #2 of 14 Old 07-18-2018, 10:36 PM
Motor7's Avatar
It looks like it's filled with old chain lube or other debris. There will be an Allen head under that black stuff, so get a dental pic and see if to can gaff all that stuff out.
'15 DL650XT
Motor7 is offline
post #3 of 14 Old 07-19-2018, 02:59 PM
D.T.'s Avatar
Not supposed to be there.
That's a allen key socket head bolt. 6 mm I think.
Hopefully it's just plastic. If someone broke off a round headed allen wrench in there it's going to be more of a challenge.
Need to dig it out of the head. If it's metal, try a strong magnet to get the stuff out.
If it doesn't come out you could try a vice grip on the outside of the bolt head. Or dremel a slot in the head and use a huge screwdriver.
D.T. is offline
post #4 of 14 Old 07-19-2018, 03:16 PM
locoblanco's Avatar
I'm puzzled. The parts diagram shows the lock washer and large hex nut, but not the crown nut. What is that ?
locoblanco is offline
post #5 of 14 Old 07-19-2018, 08:07 PM
D.T.'s Avatar
Speed rotor. It's elsewhere on the parts diagrams. Speedometer.
Sent from my LGLS676 using Tapatalk
D.T. is offline
post #6 of 14 Old 07-20-2018, 01:46 AM
2013VEE650's Avatar
Yes, you have to find the hex key hole under there.
Lock the rear brake by jamming something onto the rear brake pedal, then turn out the hexbolt.
After that, remove the bent lockwasher then find the big nut that needs to come off.. that's the tuff one!. I tried everything but an airgun.. no luck. Bought a Sears airgun but my double hotdog compressor won't put out the pressure necessary to undo it.
Gun wants 6.0 cfm at 90# and mine only puts out 3.9 at 90#.. so never got it off yet😞
2013VEE650 is offline
post #7 of 14 Old 07-20-2018, 02:59 AM
Ive used my [email protected] psi CFM 60-gal compressor with my Ingersoll Titanium 1/2" air impact and had problems with some countershaft nuts that you'd swear were welded on. NO MORE!
I place a section of 2" X 4"in the rear wheel spokes, transmission in neutral, and use a Snap-on Lithium 18 volt 1/2" impact. 600 ft-lbs, it doesnt even hammer, the nut just spins right off. A friend of mine uses a DeWalt version, same deal.
MAZ4ME is offline
post #8 of 14 Old 07-20-2018, 08:58 AM
Motor7's Avatar
Yes, Impact, air if you have a big compressor like me, or electric....both make this stuff easy.
'15 DL650XT
Motor7 is offline
post #9 of 14 Old 07-20-2018, 09:20 AM
I just replaced the chain and sprockets on my 2013. That screw was held in with industrial-grade thread locker! I thought I was going to break my hex-key, but it broke free finally.
If you don't have the skookum impact wrench you will most likely need a cheater bar on your socket wrench. The torque spec for the front sprocket is 105 lb-ft, so it's on there good and tight. I used a flat wrecking bar wrapped in rags to lock the back wheel against the rear fork.
2013 DL650A, OEM centerstand, Powerlet outlet, Parabellum windshield with X-screen deflector.
scritch is offline
post #10 of 14 Old 07-20-2018, 09:21 AM
Fox
Fox's Avatar
Have you tried a good old big-ass breaker bar? I have to stand on mine to break the cs nut loose.
Fox is offline
