Cable guides - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-11-2018, 03:09 PM Thread Starter
TwoBritts's Avatar
Cable guides
On my 2014 650 there are two 8mm screws under the top triple tree that secure the wire cable guides. I am going to use those screws in that location to mount an accessory tray. The one on the left side can be gotten to with a tiny 8mm ratchet head spanner. The right one, I have no idea. Any advice on how to get to it would be appreciated. I'm trying not to have to destroy the original parts to remove them. Thanks in advance.
TwoBritts is offline
post #2 of 4 Old 07-11-2018, 04:19 PM
Banned
1/4-in to 1/4-in U-Joint Socket Adapter
I recently installed a Richland Rick accessory tray and used a 1/4-in to 1/4-in U-Joint Socket Adapter between my 8mm socket and 1/4" drive ratchet to make the connection. I believe I mounted the cable guides over the accessory tray.
Mine was on a 2006 DL650, but the same tool may work for you.
XLonDL650 is offline
post #3 of 4 Old 07-13-2018, 04:20 PM
I use my 1/4" drive 12" extension to go up from the bottom.
Got the heart attack over and done with - Prudhoe Bay or Bust!
slane6 is offline
post #4 of 4 Old 07-21-2018, 09:22 PM
yup that one is a bitch
keep at it wobble extensions and or swivels
brutalguyracing is offline
