where and how to instal relay for grip heater - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 14 Old 07-10-2018, 11:41 AM Thread Starter
hi folks. I´ve installed a oxford grip heater in my dl650(2015). Currently its connected directly to the battery, if i forget to turn it off, i will be in trouble. I´ve been thinking on add a relay connected on ignition, so i won´t have battery issues. Any suggestions? thanks for your support
Ricieri is offline
post #2 of 14 Old 07-10-2018, 11:47 AM
There is a factory connection point for heated grips. Check the “sticky” aux connector and heated grip connector location. That might be a good option for you.
wingstrom is offline
post #3 of 14 Old 07-10-2018, 11:48 AM
Get the heated grip harness from Eastern beaver, then you will have switched power and it's plug and play.
https://www.easternbeaver.com/Main/B...om/vstrom.html
JeepDawg likes this.
post #4 of 14 Old 07-10-2018, 06:22 PM Thread Starter
thanks guys, I had no idea that the harness have the connector for heated grips... and believe it or not, the oxford grips were installed by suzuki dealer... i´ll go back there and ask them to rearrange the wires properly. thanks
wingstrom likes this.
Ricieri is offline
post #5 of 14 Old 07-10-2018, 07:58 PM
ScottKY's Avatar
My Oxford heated grip have a feature that senses the drop in voltage when the bike isn’t running and turns off after some short amount of time, 30 seconds or minute, if I recall correctly. I assume yours have the same feature.
-Scott
ScottKY is offline
post #6 of 14 Old 07-10-2018, 10:14 PM
Rolex's Avatar
Oxford recommend you hook directly to the battery.
They will shut down a few minutes after stopping the motor so no relay is required.
I have been using Oxfords for years and have never had a problem hooked directly to the battery.
vinnyvavoom likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 14 Old 07-11-2018, 11:25 AM
chicago's Avatar
I hooked my oxford grips direct to the battery per the instructions. They are designed to shut off when sensing low battery voltage if you leave them on. Nothing wrong with hooking them up to switched power or using a relay though for a bit of peace of mind.
14 tooth for me
chicago is offline
post #8 of 14 Old 09-18-2018, 07:18 PM
Looking for heated grips. Should I go Oxford or Suzuki? And if Oxford, which model?
2013 DL650A, OEM centerstand, Powerlet outlet, Parabellum windshield with X-screen deflector.
scritch is offline
post #9 of 14 Old 09-18-2018, 08:16 PM
I've had both and Oxford is far more warmer than OEM's.
emjrrider is offline
post #10 of 14 Old 09-18-2018, 08:28 PM
Thanks! And there's no problem with the bar ends? I have Barkbusters installed.
I suppose you have had no trouble with them being water-resistant, too?
scritch is offline
