Alternates to OEM forks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 29 Old 07-04-2018, 12:38 AM Thread Starter
Dny209's Avatar
Unhappy Alternates to OEM forks
Hello, I am new to this forum. I just bought a 2012 DL650 from the insurance auction and the front forks are bent. In my search to find replacements I was unable to find a used oem pair (or even one of them) anywhere on ebay, salvage yards etc.. Is there any cheaper replacements than new OEM ? They are about 650 each minimum [B]yikes..[B] Im already in 1500 for the bike, and if the tubes are this expensive I might just have to sell it or part it out because it would end up being to expensive, I would rather search for a clean running one. The bike has 25k miles it was listed as starts and runs but I cant get it to even crank.. I hear the fuel pump but nothing happens even with a jump pack on it.
Anyways, any alternative out there? Any other year that is interchangeable like 2004-2011 ? or from other models?
2012 Dl650
Dny209 is offline
post #2 of 29 Old 07-04-2018, 03:20 AM
I can't tell you if any other forks are interchangeable, but I can tell you that both upper and lower fork tubes have different part numbers between the '12-'16 models and the '11 and earlier model DL650 Vstroms.
The most commonly bent items are the upper tubes which from what I've seen, are $253 each. Exactly what is bent on your forks, can a part replacement instead of a complete assembly take care of this?
As for your no-crank condition, have you tried bypassing(jumping) the clutch and/or the sidestand switch? Just 2 possibilities before regular starting system diagnosis.
Gert and Chipwidget like this.
MAZ4ME is offline
post #3 of 29 Old 07-04-2018, 09:03 AM
I replaced a set of bent fork tubes for $400+-. They were ordered from Italy through Adventure Power Sports, LLC.
post #4 of 29 Old 07-04-2018, 09:07 AM Thread Starter
Dny209's Avatar
Thank for the reply.. I just seen the bent forks so I started looking for the entire assembly. Although it did look like the top tube is what was bent so hopefully that is it 600ish wouldnt be horrible aslong as I can get the bike running good before I staft throwing more mlney at it.
The clutch lever was nkt broken nor was the side stand so I did not think about doing that.. im assuming it should be something simple since the auction had it listed as a starts and runs.. although it did sit for atleast 3 months at the auction since they only sell motorcycles every so often.
I dropped it off with a mechanic yesterday to checkout the no start issue . I will be going by today to check it out.
Are bent forks/upper tubes something a novice DIY'er can do ? I never worked on motorcycles only cars but it would be nice to save some money on this bike if I can or should I leave this work to the shop?
Thanks
2012 Dl650
Dny209 is offline
post #5 of 29 Old 07-04-2018, 09:11 AM Thread Starter
Dny209's Avatar
Wow , thanks for the link I will look into this asap 400 for the set is a good deal!
Now I took a quick glance at the website and it seems like the vendor focuses on rebuilding and making the suspensions better, but they sell individual components as well?
Im going to contact them today anyways, i appreciate the link
2012 Dl650
Dny209 is offline
post #6 of 29 Old 07-04-2018, 09:49 AM
Bikehigh's Avatar
Race Tech lists replacement fork tubes for $175 each. http://www.racetech.com/TNKProductSe...20V-Strom/2012
Mulewright likes this.
Bikehigh is offline
post #7 of 29 Old 07-04-2018, 10:39 AM Thread Starter
Dny209's Avatar
Wow my man ! Thanks alot , I really did search up and down the web before posting here and I could not find anything but I knew posting here would be my best bet since it is a community dedicated to stroms. With that price im sure I will be fixing it up now . Hopefully everything else is good , I will probably post a thread with the rebuild progress.
mpom likes this.
2012 Dl650
Dny209 is offline
post #8 of 29 Old 07-04-2018, 11:18 AM
Only joined a couple of years ago so am newbie myself, but welcome to the hive!
Great folks and great info.
There are switches associated with the clutch lever and side stand to prevent starting engine when its deemed unsafe by Suzuki, something your mechanic should check.
Mark
mpom is offline
post #9 of 29 Old 07-04-2018, 12:51 PM Thread Starter
Dny209's Avatar
Mark
Thanks. Im going to check for an update today hopefully some good news
2012 Dl650
Dny209 is offline
post #10 of 29 Old 07-04-2018, 12:58 PM
If the tubes are bent but not creased, they can be straightened. I had mine straightened for $50. Good as new now.
wingstrom is offline
