Temperature switched to Celsius - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 14 Old 06-25-2018, 09:28 PM Thread Starter
Who?'s Avatar
My temp somehow switched to Celsius... how do i switch it back to Fahrenheit ? 2012 Glee
Who? is offline
post #2 of 14 Old 06-25-2018, 10:05 PM
According to the manual, toggle to the regular odometer setting. (let go of it then.)
Then hold the Adjust button, the rubber button on the left, for 2 seconds. Then you can select between Miles and KM.
I'm not sure how, as I'm not near the bike now, but this is the extent of the manual's directions.
If you choose Miles, you'll get Fahrenheit.
philmc is offline
post #3 of 14 Old 06-25-2018, 10:33 PM Thread Starter
Who?'s Avatar
will give it a try... I did manage to change from miles to kilos and back but temp is still Cel..... will let you know shortly
Who? is offline
post #4 of 14 Old 06-26-2018, 12:15 AM
bnucci24's Avatar
I think you need to change mpg back to mpg US style. The one that also shows C is imperial mpg i think. One affects the other. Look closely. Good luck
bnucci24 is offline
post #5 of 14 Old 06-26-2018, 01:10 AM
p38arover's Avatar
Good to see you catching up with the rest of the world.
chicago, Toadster and V-Harry like this.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #6 of 14 Old 06-26-2018, 01:51 AM Thread Starter
Who?'s Avatar
Got it.... It was set to Imperial gal, no idea how that happened..... when i fired it up the other day i thought i'd have to get the snow suit out when it said 22 degrees.....
Feet, Inches, miles, gallons, all used by the country that has landed men on the moon... everybody else uses metric.
Thanks guys
eagleeye likes this.
Who? is offline
post #7 of 14 Old 09-21-2018, 09:55 PM
Actually NASA used a combination of metric and imperial on the Apollo missions and is in the final stages of abandoning imperial altogether. science.nasa.gov/science-news/science-at-nasa/2007/08jan_metricmoon
Thanks guys
Sent from my Lenovo TB-X304F using Tapatalk
drikko is offline
post #8 of 14 Old 09-21-2018, 11:46 PM
MrF
MrF's Avatar
Thanks guys
I've done that accidentally before after filling up:
1. Write down miles
2. Toggle to MPG, write down MPG
3. Forget I'm on the MPG display and hold down the adjust button to reset my trip meter.
4. Get frustrated that it's not resetting.
5. Realize I'm on the wrong display and toggle five more times to get back to the trip meter.
6. Reset the trip meter (finally) and forget that I changed MPG.
And I'd be lying if I said this has only happened once.
2016 V-Strom 650
MrF is offline
post #9 of 14 Old 09-22-2018, 07:38 AM
p38arover's Avatar
Thanks guys
A few years back, whilst returning to SFO from Yosemite, IU saw a sign that said San Fran 187 miles. I thought that was an odd figure. Then it hit me - so I got out my phone and calculated the distance in km. It was 300km.
Maybe they were ready to change to km but it got stopped.
Everyone on board the bus (except the driver) were from metric countries so they understood the distance when given in km. I can use both but when I was in the UK a few years back, I reset my GPS to give the distances in km - I'm so used to km now even though I was brought up on the Imperial system (we changed in 1974).
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
post #10 of 14 Old 09-22-2018, 08:46 AM
locoblanco's Avatar
When the display is toggled to the mpg reading, press and hold the adjust button to switch between us and imp. Can also switch between km/L and L/100km.
(I just learned that a few minutes ago, prompted by this thread to consult the manual and verify. Good way to start the day, learning something new.)
locoblanco is offline
