Available accesories wire/plug? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 19 Old 06-23-2018, 12:13 AM Thread Starter
ilan's Avatar
Hi, I want to install a cam. Is there an available accessory wire, alive only when the bike is on?
Thanks,
Ilan
My Rides: Suzuki TS50, Honda CB400 Superdream, Yamaha RD350LC, Triumph Tiger 650 (71), MotoGuzzi NTX 650, Ducati 750SS (93), Yamaha XTZ 750 SuperTenere, Vespa 200PX (01), Vespa Sprint 150 (68 ) ... Although ridden, never owned a four cylinder :-)
ilan is offline
post #2 of 19 Old 06-23-2018, 03:30 AM
MAZ4ME is offline
post #3 of 19 Old 06-23-2018, 11:21 AM Thread Starter
ilan's Avatar
Hi, thanks its very informative, still Im wondering is there's a switched wire in the front area, that is intended to connect accesories, instead of striping a wire?
ilan is offline
post #4 of 19 Old 06-23-2018, 11:30 AM
Look under popular forums, 2012-2016 dl650, Aux Connector thread
or just google stormtrooper aux connector
Hatchi is offline
post #5 of 19 Old 06-23-2018, 11:35 AM
Yah, it's hidden on the left side near the radiator on the older models. Eastern Beaver make a jumper for it or available from your handy Suzuki dealer.
post #6 of 19 Old 06-23-2018, 11:56 AM
chicago's Avatar
another option I've used is a positap connector, from posi products. taps into a wire with no stripping/damage. available from a few sources online.
https://www.posi-products.com/
14 tooth for me
chicago is offline
post #7 of 19 Old 06-24-2018, 05:17 AM Thread Starter
ilan's Avatar
Thanks a lot!
ilan is offline
post #8 of 19 Old 06-24-2018, 10:33 AM
I did almost exactly this for my Mobius cam, but tapped the wire EB Accessory Adapter wire to also feed my USB port.
Note the accessory plug only provides limited power.
thirdofthree is offline
post #9 of 19 Old 06-25-2018, 01:07 AM
There are two switched accessory plugs on the Glee. The one behind the top left corner of the radiator is intended for heated grips and it is difficult to get to - remove tank, tilt radiator etc. There is another in the right side of the fairing intended for all your little electronic doodahs. You can access this without removing any panels but it is tight, probably easier to pull some plastic off but this is easy, only takes a few minutes.
With a torch you will see the wiring harness tied to the vertical fairing mount bracket. Just fiddle a bit, unwind some tape and you will see the plug. I couldn't find a matching plug locally (Eastern Beaver i am sure will have them) so just cut it off & joined on with Waygo terminals. I used it to run a USB port up on top of the instruments. It has been powering my GPS happily for ~10,00km now.
vinnyvavoom likes this.
Chipwidget is offline
post #10 of 19 Old 06-25-2018, 05:18 PM Thread Starter
ilan's Avatar
Thanks!
I like the word doodahs!
ilan is offline
