electrical problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By BC Rider
  • 2 Post By Gert
post #1 of 10 Old 06-19-2018, 09:09 PM Thread Starter
electrical problem
Signal fuse shorting-my fuse keeps burning out and I’m losing power to my signals, break lights and instrument panel. Any ideas what’s causing the fuse short.
lev99 is offline
post #2 of 10 Old 06-19-2018, 09:28 PM
chicago's Avatar
what electrical accessories (if any) have been added to the bike?
has any work been done recently to the bike?
14 tooth for me
chicago is offline
post #3 of 10 Old 06-20-2018, 12:16 AM
BC Rider's Avatar
Either it is an overload from adding accessories or a dead short. Also make sure it is the correct value fuse inserted. Not a 5 amp where a 10 should be. Overloads can appear random as it may not blow till accessory are on, turn signal is on, you touch the brake and pop. More than likely a wire had abraded and touches metal now n again.
Big B likes this.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #4 of 10 Old 06-20-2018, 12:49 AM
BC Rider's Avatar
also, have a look at this. https://www.stromtrooper.com/.../6284...rt-solved.html
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #5 of 10 Old 06-20-2018, 01:48 AM
Rolex's Avatar
First try to work out when the fuse blows.
Is it when you use the left or right signal or when you use the front or rear brakes ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 10 Old 06-20-2018, 05:37 AM
Gert's Avatar
I suggest that you 1st make a test lamp for yourself. Place the test lamp lead in the fuse holder, on the side leading the gauges / brake light / signals, test from there to reproduce your fuse blowing problem. The test lamp will save you a few fuses and aid your in tracing your fault.
pvwheeler and G-Dub like this.
Gert is offline
post #7 of 10 Old 06-21-2018, 07:25 AM Thread Starter
I haven’t added any new accessories for a year so don’t think thats the problem. When the fuse blew my signal and brake lights were not in use. The fuse blows as soon as I start the bike and the instrument panel comes on. Maybe something to do with that?
lev99 is offline
post #8 of 10 Old 06-21-2018, 08:07 AM
I'd guess most likely an abraded wire touching metal. I would pull the fairings, fuel tank, etc. and just start carefully looking at all the wiring and harnesses. You could also unplug things you suspect, like the instrument panel, and try starting it.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #9 of 10 Old 06-21-2018, 08:44 AM
chicago's Avatar
there was a recall for some models in some countries re frayed wiring. May not involve your model/market but might be worth investigating and eliminating.
Suzuki Cycles - Recall-Letters
14 tooth for me
chicago is offline
post #10 of 10 Old 06-25-2018, 08:40 PM
BC Rider's Avatar
If it isn't an overload then it is a short. If it pops just turning on the ignition and not when signals or brakes are used it is in the wiring before the switches. Is tail lamp on same fuse? Check under the seat in the trunk, maybe something stuffed in there has damaged a wire. Look down by the rear brake switch. Look in the easy areas first before tearing stuff apart.
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
