Clock/Temperature alternating - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
  • 6 Post By Anduril
  • 2 Post By Blue Goose
post #1 of 10 Old 06-19-2018, 11:24 AM Thread Starter
Blue Goose's Avatar
My ride is a 2015 DL650A. The clock/temp alternate while riding. Is this normal or is this a setting that I am not aware of??
The owners maual does not describe it!! Any feedback is always appreciated.
Blue Goose is offline
post #2 of 10 Old 06-19-2018, 11:30 AM
Definitively not normal from what I've seen with mine, holding in on the selector switch is what changes that display reading.
post #3 of 10 Old 06-19-2018, 11:33 AM
Cal Scott's Avatar
Not normal behavior that I am aware of. On my 2013, you toggle between clock and temperature by holding in the selector switch on the front of the left hand grip for a couple of seconds. When you figure out how you managed to get it to alternate, do let me know. I wouldn't mind having that as an option .
Cal Scott is offline
post #4 of 10 Old 06-19-2018, 12:20 PM
ptcaflyer's Avatar
Sounds like the handle bar button is stuck...try pressing it a few times an letting it "Snap" back...
Mine does not cycle its either/or...
'15 DL650A
ptcaflyer is offline
post #5 of 10 Old 06-19-2018, 12:44 PM
Can happen, if your clutch lever is wrongly tilted and while pressed, it's pressing the Meter button.
2015 DL650XT
Anduril is offline
post #6 of 10 Old 06-19-2018, 01:33 PM
Or, if it's rightly tilted.
This happened to me when I adjusted the clutch rotation to where I wanted it. Just had to rotate the control pod a bit to avoid the clutch depressing the button.
thirdofthree is offline
post #7 of 10 Old 06-20-2018, 10:08 PM Thread Starter
Blue Goose's Avatar
Thanks Guys for the feedback. I will follow the recommendations and see what happens.
Whatever the result, I will post it.
post #8 of 10 Old 06-23-2018, 02:12 PM
Yep, exact same thing happened to me. Adjusted the clutch lever rotation and couldn't figure out why it would swap clock/temp "randomly". "Randomly" just happened to be every time I shifted....
Got the heart attack over and done with - Prudhoe Bay or Bust!
slane6 is offline
post #9 of 10 Old 06-23-2018, 07:53 PM Thread Starter
Blue Goose's Avatar
Anduril Hit it on the head!!!👍
The clutch lever was hitting the selector switch & changing time/temp. Move the lever slightly and everything is back to normal.
Thanks for the feedback guys!!!👌
Big B and Anduril like this.
post #10 of 10 Old 06-27-2018, 04:20 AM
Love a simple fix
Harry
V-Harry is offline
