Abs light - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By wadestrom
post #1 of 7 Old 06-02-2018, 09:12 PM Thread Starter
Abs light
So I was flying home tonight. Running the balls off the bike because i was seriously going to crap my pants. Over 100 mph. I was almost home and the abs light came on. Locked up the rear brake before pulling in the driveway. Bike only has 3300 miles. Anyone else had this happen?
ehart814 is offline
post #2 of 7 Old 06-09-2018, 06:47 PM
wadestrom's Avatar
Yes mine comes on in the rain, not sure why. I think it may be the abs sensor on the wheels gets dirty and can't read the wheel speed anymore????
2012 Glee, Givi E22n/Shad SH45 Topcase
wadestrom is offline
post #3 of 7 Old 06-09-2018, 08:45 PM
suzukik9rider's Avatar
Has the light stayed on or does it go off after reaching approx 5mph. If the light goes off then the fault was only temporary and fixed itself, (but the fault will still remain logged in the ABS HU module until manually cancelled.) If the light remains on then the fault still exists.
suzukik9rider is offline
post #4 of 7 Old 06-10-2018, 10:34 AM
wadestrom's Avatar
Mine normally comes on in rain and would go off after cleaning the sensors, this time it has stayed on even after cleaning, I am going to check fuses next. Battery is only 1 year old and connections are clean and tight.
post #5 of 7 Old 06-10-2018, 12:21 PM
light remains on.
DO NOT PULL CIRCUIT BREAKERS - If you remove power from the ABS HU module then you will lose the logged diagnostic fault code which is stored in RAM memory in the ABS HU module.
Get a service manual for your bike.
Rather than randomly guess at what may be the fault it's time for diagnosing.
post #6 of 7 Old 06-10-2018, 12:47 PM Thread Starter
My bike was pretty dirty when this started. It will come and go. Sometimes I go for a ride and the light stays off and abs works. Yesterday I cleaned the bike really well. Went for a ride and it was okay. Took another ride a few hours later and the light came on and stayed on.
ehart814 is offline
post #7 of 7 Old 06-10-2018, 01:27 PM
wadestrom's Avatar
I have a service manual, all fault codes relate to sensor fault, sensor rotor damage, bad battery, rectifier issue or wiring fault.
Since I have already checked sensors and rotors(visually) and they appear to be fine, the next easiest item would be wiring issues starting with fuses.......
I pulled and replaced fuses and sprayed the fuse holder with electrical contact cleaner and the ABS light is working as normal, ie. Light comes on with ignition, then goes out once moving. To test I put the old fuses back in and tried again and the ABS light came on and stayed on during riding. So I replaced the fuses with the new ones and back to normal. The fuses were not blown but the blades were corroded. I then replaced all fuses and cleaned the fuse box with electrical contact cleaner just in case.
If I get another fault I will go to a shop for deeper diagnosis.
ehart814 likes this.
