Dl 650 vs DLA 650A - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-15-2018, 11:42 AM Thread Starter
Dl 650 vs DLA 650A
Can some please assist, I am getting ready to replace the front fork seals on my V-Storm DLA650A, I found the parts through a company called Air Balls for the entire seal and bushing kit, which will fit DL650 will the same seal kit work for the DL650A? I thought the A stood for ABS brakes, but was not sure if it would make a difference on the seal kit for the front forks. One more questions does anyone know of place to download a maintenance manual for the DL650. I can buy one on line, but was hoping to be able to download one to same time. Any help would be greatly appreciated.
Henry K
Knipper64 is offline
post #2 of 4 Old 05-15-2018, 12:30 PM
Same forks on all the 650's.......buy away. And ZERO discussion or sharing of pirated manuals here.
post #3 of 4 Old 05-15-2018, 11:21 PM
https://blacklabadventures.com/
For those without a clue and no manual. Lot's of us have bought used, like new, manuals from fellow members here. Order up a Haynes too.
i used the Black Lab tutorial and realized I was repeating the same steps i used doing a '76 BMW R75/6 fork. There isn't much new science in forks.
The seal kits I got from the dealer and the fork oil was only 80-90 bucks. Not a wallet killer.
post #4 of 4 Old 05-16-2018, 05:39 AM
Motor7's Avatar
I would not use All Balls fork seals. I have read(not experienced) that most non OEM seals do not hold up, the difference in $ is peanuts to go OEM or SKF. You can most likely get them from Daugherty:
Daugherty Motorsports - Motorcycle Suspension Performance and Modification
'15 DL650XT
Motor7 is offline
