Shift lever clamping bolt upside down ok? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 13 Old 05-11-2018, 01:29 AM Thread Starter
Is it okay to leave the clamping bolt in this way instead? It makes more sense than the default to me, but then why do they do it?
Oops365 is offline
post #2 of 13 Old 05-11-2018, 03:01 AM
gspy4u's Avatar
Can't see any reason why it would be a problem as long as it tightens up the same. Also it won't drop off if it ever comes loose.
gspy4u is offline
post #3 of 13 Old 05-11-2018, 04:08 AM
The clamp is only threaded on one side. The bolt must always be installed with nut opposite of threaded end in order to squeeze the ends together.
Willie is offline
post #4 of 13 Old 05-11-2018, 07:32 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Yep. What Willie said. +1
richlandrick is offline
post #5 of 13 Old 05-11-2018, 07:13 PM
as long as it clamps tight and the shift arm is as close to 90 degrees to the arm its all good.
jccity6 is offline
post #6 of 13 Old 05-11-2018, 08:28 PM
Brockie's Avatar
What Willie said. The clamp is only threaded in the bottom half of the hole. Otherwise it will not grip on the splines.
Brockie is offline
post #7 of 13 Old 05-11-2018, 09:13 PM
Left like that, it is possible that it will spread and slip under hard use, or could even crack and break off.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #8 of 13 Old 05-11-2018, 10:31 PM
STCorndog's Avatar
uhh, it is friday.
uhh, I did mount some new tires tonight and am now celebrating that little victory with craft beer number 3.
uhh, there aint no nut.
there is only a bolt and it went through the open hole, threaded into the side where the threads are and clamped the clamp thingy. The only way to have the bolt on the bottom would be to remove the bolt, remove the arm, rotate the arm, put the pivot like it belongs to make the rod thingy straight, then the bolt thingy would go in from the bottom.
(Edited for a moment of clarity between beers 3 and 4.)
Old Codger and BC Rider like this.
STCorndog is offline
post #9 of 13 Old 05-11-2018, 10:52 PM
STCorndog's Avatar
And....uhhh, the bike is going to shift 1 up and 5 down the way you have it.
I think?
post #10 of 13 Old 05-11-2018, 10:57 PM
STCorndog's Avatar
You better fix this....I think.
When you click down you will be in second.....then the bike will lug and take off. then if you wind out second you will lift up on the lever and hit first......which might get exciting.
