Weird LED headlight problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-09-2018, 09:43 PM Thread Starter
Put in a new set of LED headlights.
When you first turn on the key, the lights start on low beams.
When you hit the high beam switch, they come up fine.
BUT...they won't turn back down to low with the switch.
If you turn off the key, they will restart on low, BUT same as above.
Any ideas?? Thanks!
BradB is offline
post #2 of 3 Old 05-09-2018, 10:29 PM
Brojon's Avatar
Did you wire through a harness? If so double check the wiring.
Sounds like the relay is getting voltage feed back to the coil keeping it energized.
"The further a society drifts from truth, the more it will hate those who speak it."
George Orwell
2015 DL650
Brojon is offline
post #3 of 3 Old 05-12-2018, 10:26 PM
I have the EB headlight harness and when I put in the LEDs all worked just like before.
Mine's an 04 so maybe some wiring differences?
