Gladius motor- interchangeable? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 33 Old 05-08-2018, 11:56 PM Thread Starter
aTuWitty's Avatar
Hi friends,
My buddy just did a valve adjustment on his 2012. Ran great in the morning and most of the way back home, and then the motor lost power and siezed up. I suspect something with the rear cam chain, but we haven't been able to confirm yet.
I DID find a Gladius motor with low miles for cheap, but I'm not sure if it's a direct drop in to the Glee. If this motor is lunched, should we buy the Gladius motor and stick it in there?
Thanks in advance!
"Definitely do not sit on a DL1000. Big mistake. You'll end up buying one. Happened to me. True story."
-busarider54
"Purchasing a V-Strom from a Harley dealer does have poetic justice. Almost like removing a talented child from a meth house."
-ShortOnSkill
"I'm for moves that will help people get over the idea that it is ever okay to drink and drive."
-greywolf
aTuWitty is offline
post #2 of 33 Old 05-09-2018, 12:53 AM
It’s based on that engine, but highly doubt it will work as a drop in if at all. Don’t jump the gun, look in the top end and see what’s going on.
post #3 of 33 Old 05-09-2018, 07:39 AM
D.T.'s Avatar
I bet you could get it to work. There are differences, like the cams are bigger and the flywheel rotor has OPEN magnets, not encapsulated.
I'm unsure about the ECU and all the sensors though. I say go for it!
D.T. is offline
post #4 of 33 Old 05-09-2018, 05:02 PM Thread Starter
aTuWitty's Avatar
Welp... Here's the front piston! There are metal shavings in the airbox. It's bad.
This will be fun to fix.
File Type: jpg Screenshot_2018-05-09-13-07-00_1525899682000.jpg (15.4 KB, 197 views)
-busarider54
-ShortOnSkill
-greywolf
aTuWitty is offline
post #5 of 33 Old 05-09-2018, 05:38 PM
ilan's Avatar
Yikes...looks like a scene from "Alien"
My Rides: Suzuki TS50, Honda CB400 Superdream, Yamaha RD350LC, Triumph Tiger 650 (71), MotoGuzzi NTX 650, Ducati 750SS (93), Yamaha XTZ 750 SuperTenere, Vespa 200PX (01), Vespa Sprint 150 (68 ) ... Although ridden, never owned a four cylinder :-)
ilan is offline
post #6 of 33 Old 05-09-2018, 07:33 PM
Brockie's Avatar
Surely all the mounting points etc. are all the same but I would be concerned about the ECU. Do you swap to a Gladius one? Would that integrate with a DL?
Finding a V-Strom motor could save you many headaches.
Big B and JeepDawg like this.
Brockie is offline
post #7 of 33 Old 05-10-2018, 09:04 AM
D.T.'s Avatar
Valve adjustment gone bad? Did it drop a valve? May be able to repair just the piston and head if the con rod isn't junk.
The crank sensors on the rotor have to be the same, and get processed the same.
D.T. is offline
post #8 of 33 Old 05-10-2018, 11:29 AM Thread Starter
aTuWitty's Avatar
The front exhausts were at .09 and .11, well below tolerance. I can't believe the thing was still running, honestly. We weren't able to get the top end off to thoroughly examine what he may have done wrong yet. The piston is holed, though, so I'd imagine that the crank bearings could be compromised from metal shards? I'm not sure, never dealt with a repair of this magnitude before.
-busarider54
-ShortOnSkill
-greywolf
aTuWitty is offline
post #9 of 33 Old 05-10-2018, 08:58 PM
Bogfarth's Avatar
Uhmm.... 0.09 to 0.11? Gads. If not a typo (missing a zero right of the decimal) how did he do that?
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #10 of 33 Old 05-10-2018, 09:56 PM Thread Starter
aTuWitty's Avatar
It's not a typo. When he got the valve cover off and checked the clearances, the exhaust valves on the front were .09 mm and .11 mm. He shimmed them to the mid .2 range and buttoned it up (did the intakes too). Motor ran fine on his 60 mile ride to work, much smoother and the bike was reporting better fuel mileage as well, and then it grenaded halfway through his return trip.
-busarider54
-ShortOnSkill
-greywolf
aTuWitty is offline
