12 O'Clock Labs Running Light Adapters Help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 11 Old 05-07-2018, 10:59 PM Thread Starter
Hi everyone,
I bought and installed the 12 O'Clock Labs Running Light Adapters for the front and noticed the turn signals get very hot now because they are always on
Does anyone know if this is normal or know what I can do to remedy?
I bought the LED Tuff Lites, but would rather stay with the stock bulbs because they are more visible.
sjsandman is offline
post #2 of 11 Old 05-08-2018, 01:06 PM
Bikehigh's Avatar
A 21 watt incandescent bulb generates heat. If it's a runniing light, it generates heat continuously. Yes, it will get hot.
LEDs of some kind are your only
option without rewiring. Don't know how they'll do as far as longevity being in such a small space and constantly on, but it would be worth a try. The other otpion would be to rewire the turn signals for 1157 bulbs.
Bikehigh is offline
post #3 of 11 Old 05-08-2018, 03:26 PM Thread Starter
Thanks, will the LED 1157 still be able to use as a turn signal and running light?
post #4 of 11 Old 05-08-2018, 03:40 PM
No need to convert to 1157. You just need to replace your stock 1156 bulbs with 1156 LED bulbs.
I have a different running light adapter, but use 1156 LED bulbs in my front running / turn signal lights. I have these, which are no longer available. You'll see a lot of similar options on the product page, though, including another offering by JDM.
Unfortunately, I can't offer a specific recommendation since the ones I use aren't available, other than I've been happy with my JDM bulbs.
When you switch to LED bulbs, your signals will flash quickly. A cheap & simple replacement of the stock flasher relay will solve the issue. I used this one.
thirdofthree is offline
post #5 of 11 Old 05-08-2018, 06:07 PM Thread Starter
Thank you, I'll give that a try. How is the brightness on those suggested bulbs compared to stock?
post #6 of 11 Old 05-08-2018, 06:28 PM
I can only speak directly to the JDM bulbs I have. Turns out they're still available direct from JDM, just not through Amazon:
JDM ASTAR Auto LED Bulbs,LED Headlight,Fog Lamps & Turn Signal Brake Tail Light
The others I linked in Amazon:
According to the JDM specs, the 1st set is 1200 lm per bulb, and the 2nd set is 1260 lm per bulb. Take those specs with a grain of salt (no one provides accurate lumen ratings these days), but at least in relative terms I think they're useful.
FWIW, I also painted the interior of my turn signal housings white (other use reflective aluminum tape or the like), and IME that helps with brightness irrespective of the type of bulb.
Here's a low quality video comparing stock bulb v. my LED bulb v. stock bulb with white-painted housing v. my LED bulb with white-painted housing:
Thighrod likes this.
post #7 of 11 Old 05-08-2018, 11:02 PM Thread Starter
Awesome! I'll give that a try. Great help, great video.
post #8 of 11 Old 05-09-2018, 12:56 AM
Letsgo2up's Avatar
I used the 12 O'clock labs adapter. I bought LEDs from Superbrightleds.com. Bought an electronic flasher unit from EBay. I think Superbright LEDs sell a Suzuki flasher. The incandescents do get too hot. I really like the running lights.
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
'07 Kawasaki KLR650
Letsgo2up is offline
post #9 of 11 Old 05-09-2018, 08:53 AM Thread Starter
If I change the front Turn/Running lights to LED, do I need to change the rear also?
post #10 of 11 Old 05-09-2018, 10:17 AM
Don't need to change the rear bulbs when you change the front.
I did, however, because I like the added brightness and the instant full-intensity on / off flash of the LED bulbs (rather than the slower increase to full intensity on / slower fade to off of the stock bulbs).
