Freezing rear brake pedal '12DL 650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 2 Post By Fox
  • 1 Post By Bikehigh
  • 2 Post By Bogfarth
  • 1 Post By Spec
post #1 of 8 Old 05-04-2018, 11:50 AM Thread Starter
So on my drive to work this morning the rear brake froze/locked up so I could NOT push it down. That was a bit scary since I was doing a flanking maneuver through busy traffic... lol. It then happened again a few times and I really had to ram the pedal to get it to engage. Something is definitely off...
Anyone had this happen?
I'm going to check it out tonight. Maybe the pads are worn or the rear brake cylinder is wore out? 28k miles now, so stuff is likely to start wearing out here and there.
Curious if anyone had this happen and what you found the issue was.
'12 DL650 ADV
'07 Victory Hammer
'06 Suzuki M50 (Traded)
MariusD is offline
post #2 of 8 Old 05-04-2018, 12:29 PM
Fox
Fox's Avatar
Had something similar happen, I could press it down with some effort but it wouldn't release with the spring force alone. Either way, if the lever doesn't move easily, the pivot point is probably dirty and dry.
To clean it, you'll need to remove the footpeg mount assembly, detach the spring, remove the snap ring and pull the lever off. Clean the shaft and cylinder well, and apply a ton of grease. Then reassemble.
It's a bit of a pain. I think I've read of someone who installing a grease fitting into the lever.
V-Tom and MariusD like this.
Fox is offline
post #3 of 8 Old 05-04-2018, 12:35 PM
Bikehigh's Avatar
I've had the rear brake stick in a partialy engaged position, so the brake would drag a bit. Took the caliper off, sprayed the cylinder area down with brake cleaner. Cleaned and lubed the pin, and sleeve bushing, and pin bolt with SilGlyde. Problem solved.
MariusD likes this.
Bikehigh is offline
post #4 of 8 Old 05-04-2018, 10:18 PM
Bogfarth's Avatar
Both. Pull the peg, lube the pivot. Pull the caliper and clean with quality brake cleaner, pop the pads and work/clean the pistons, clean and lube the pad pin. An hour later, all should be right with the world.
Fox and MariusD like this.
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #5 of 8 Old 05-08-2018, 05:33 PM Thread Starter
Thanks everyone who commented. I've had a very busy weekend with family visiting so haven't gotten to inspect the bike, but hope you all are right and all it will take is some cleaning/lubing to get it back to normal. I'll update the thread once I get to inspect it.
'12 DL650 ADV
'07 Victory Hammer
MariusD is offline
post #6 of 8 Old 05-08-2018, 05:55 PM
Spec's Avatar
You know that there's a front brake right?
Works better too!
notacop likes this.
Spec is offline
post #7 of 8 Old 05-09-2018, 12:09 AM Thread Starter
Works better too!
Lol... sure, thats what saved me, but using just the front in a middle of a sharp maneuver definitely throws the bike off balance, and makes for a very scary experience.
'12 DL650 ADV
'07 Victory Hammer
MariusD is offline
post #8 of 8 Old 05-09-2018, 12:28 PM
In winter, my '07 Wee experienced rear brake lever sticking. It needed lube, and was hard to get to it. At that time GW mentioned adding a grease fitting to the lever, which I didn't do.
Fast forward to my '12 Wee. Damage to lever caused lever replacement. I installed a grease fitting in the new one before install. Now nice and easy to lube, and a thorough lube job done too.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 45K+. Love it!
HokiesRWee is offline
