Front lights stopped working and then resumed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By Hatchi
post #1 of 7 Old 04-25-2018, 01:57 PM Thread Starter
ilan's Avatar
Hi,
This was a bit of a rainy day. I started the bike at the evening and noticed the two front lights stopped working. High beam as well. ALL other lights worked fine.
After 15 minutes of riding (with the givi side lamps and hazard lights) the main lights suddenly resumed.
Any idea what to check?
Thanks,
Ilan.
My Rides: Suzuki TS50, Honda CB400 Superdream, Yamaha RD350LC, Triumph Tiger 650 (71), MotoGuzzi NTX 650, Ducati 750SS (93), Yamaha XTZ 750 SuperTenere, Vespa 200PX (01), Vespa Sprint 150 (68 ) ... Although ridden, never owned a four cylinder :-)
ilan is offline
post #2 of 7 Old 04-25-2018, 02:46 PM
The tiny starter switch contacts can overheat from all the headlight current going through them. Here are some good contact cleaning instructions from BlackLab:
https://www.stromtrooper.com/maintena...ance-pics.html
Install the H4 dual headlight relay from Eastern Beaver as a preventative:
http://www.easternbeaver.com/Main/Pr...s/h4_kits.html
richlandrick and Motor7 like this.
Hatchi is offline
post #3 of 7 Old 04-25-2018, 08:03 PM
chicago's Avatar
yeah the problem comes up often enough. headlight relay will prevent that once problem is located and remedied. starter switch probably but other locations have been reported too I think.
14 tooth for me
chicago is offline
post #4 of 7 Old 04-25-2018, 08:23 PM
Good point, one of the four connections above the radiator has the headlight power going thru it. Those also get soaked with water and are not waterproof.
Hatchi is offline
post #5 of 7 Old 04-26-2018, 08:39 AM Thread Starter
ilan's Avatar
Thanks, you were right on the spot. it probably is the starter switch, pressed it couple of times and lights turned back! It was probably some water, isn't it supposed to be waterproof? 😉
Is there a way to prevent it? Some kind of spray maybe?
ilan is offline
post #6 of 7 Old 04-26-2018, 09:32 AM
D.T.'s Avatar
Lights go out when starter button is pushed. Gives the starter a bit of a boost.
Make sure there isn't junk in the switch. Get rid of corrosion, clean, lube.
D.T. is online now
post #7 of 7 Old 04-26-2018, 10:17 AM
chicago's Avatar
Originally Posted by V650-2014 View Post
Thanks, just found the problem, its probably the starter switch, pressed it couple of times and lights turned back! It was probably some water, isn't it supposed to be waterproof? 😉
fairly common complaint. contacts get 'cooked' because of too much current flowing through them. contacts need to be cleaned and a a relay will prevent future occurences. several threads on the subject including how to take apart/clean.
14 tooth for me
chicago is offline
