14,500 (24,000km) mile service - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 30Likes
post #1 of 44 Old 03-21-2018, 07:47 PM Thread Starter
Moderating in moderation
Vindex1963's Avatar
Have everything I need for my valve clearance check, I hope. I don't want any last minute surprises
do I need anything else?
Service manual (not shown)
Feeler gauges stepped in the size I need for checking the valves
New spark plugs (might as well while I'm in there)
New coolant silicate borate free
Oil change and filter
chain lube (it's due)
brake fluid to flush the brakes
sockets and allen wrenches
2015 Suzuki V-Strom DL650 bought new 4/26/17
2015 Victory Cross Country bought new 7/11/15 (dyno tuned 118hp 116tq)
If it's not broken, make it better
My take on oil: Name brand, wet clutch compatible.....BAM good to go.
Vindex1963 is offline
post #2 of 44 Old 03-21-2018, 07:56 PM
Leave the plugs be, replace them at next check.....everything else looks good, where are the torque wrenches?
marcham likes this.
post #3 of 44 Old 03-21-2018, 08:12 PM Thread Starter
Vindex1963's Avatar
OK I'll leave them alone.
I have a torque wrench in my tool box.
post #4 of 44 Old 03-21-2018, 10:37 PM
marcham's Avatar
I'm working on the same on my 2015 ...
Vindex1963 likes this.
2015 VSTROM 650 X ABS EXP
marcham is offline
post #5 of 44 Old 03-21-2018, 10:41 PM
beers for documentation and pics and tips
brutalguyracing is offline
post #6 of 44 Old 03-22-2018, 12:16 PM
Technically...
Air filter is due as well.
Also, I've been told fuel filters are good to replace often.
'12 DL650 ADV
'07 Victory Hammer
'06 Suzuki M50 (Traded)
MariusD is offline
post #7 of 44 Old 03-22-2018, 06:57 PM Thread Starter
Vindex1963's Avatar
Do I need to drain the gas tank or is there a check valve to keep the gas from pouring out?
post #8 of 44 Old 03-22-2018, 07:12 PM
New valve cover gaskets?
When you disconnect the fuel line from the fuel pump that lives inside the tank, no fuel will flow out. So don't worry about that. Just have a rag handy to catch the few drops that will inevitably spill.
brutalguyracing likes this.
BackPacker is offline
post #9 of 44 Old 03-22-2018, 07:35 PM Thread Starter
Vindex1963's Avatar
Aren't the valve cover gaskets reusable?
post #10 of 44 Old 03-22-2018, 09:57 PM
Here's my list when I did it:
Shim kit
Metric feeler gauge
Molybdenum grease
Rubber head gaskets
1211 Three Bond Silicone
Coolant
Air Cleaner
Air cleaner foam
ACF50 spray
Tie wraps
Inner tube
4 spark plugs
Hatchi is offline
