Can't get a good seal for brake fluid replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 16 Old 03-20-2018, 12:47 PM Thread Starter
bajakirch's Avatar
Over the weekend I worked on replacing my front brake fluid. A few years back I purchased a Harbor Freight vacuum pump to make this an easier job, but this is the first time I've used it on the Wee.
I had a heck of a time getting the pump tube to seal on the nipple. When I used the pump, it introduced air into the tube and decreased my pump efficiency. Also, it introduced the possibility of air getting into the brake system.
I should note that I'm fairly confident the bubbles I saw in the vacuum hose were not coming from the brake system -- I'm not experiencing any symptoms of air in the system before or after my project (spongy brake handle, etc.).
I tried a couple of different approaches to get it to seal, including:
- A small spring clamp, but the clamp was too long for the nipple.
- Holding pressure on it with my fingers, but it proved impossible to hold, pump, and fill without three hands.
I'm open to suggestions, as I plan to do the rear brake this weekend.
bajakirch is offline
post #2 of 16 Old 03-20-2018, 12:58 PM
locoblanco's Avatar
You can always just bleed the old fashioned way, pump the lever, bleed, pump, repeat. The calipers and master cylinder are close enough to each other for it to be a one person job, (unless you have really short arms).
V-Strom Ry 2 likes this.
locoblanco is offline
post #3 of 16 Old 03-20-2018, 01:44 PM
RCinNC's Avatar
I think you'll have better success if you reverse bleed the brakes. Air wants to flow up, not down, so pushing the air bubbles back up towards the reservoir is a lot easier than trying to pull it down towards the caliper. All you need to reverse bleed them is a large syringe and some tubing.
I've tried the vacuum pump for bleeding brakes, and had the same issues. You can try putting a blob of grease around the junction between the vacuum tube and the bleeder, and that sometimes works to make a seal. It's also really messy. Given the choice between the vaccum pump and just using the brake lever, I'd go back to using the brake lever.
I bought a couple large syringes and tubing from Amazon in a kit, for about 14 bucks.
Here's a good video from Youtube on how to do it. There are a bunch of others on there also.
RCinNC is offline
post #4 of 16 Old 03-20-2018, 02:44 PM
jurgenk's Avatar
I have seen a cable tie used to help seal the hose around the nipple and that may work for you.
Brad
12 DL 650
00 KLR 650C
jurgenk is offline
post #5 of 16 Old 03-20-2018, 02:45 PM
When I bled my brakes the first time (using a manual kit, with a one-way valve) I saw a lot of bubbles in the clear plastic line from the bleed nipple. Had a hard time figuring out where it came from, and eventually concluded that this was outside air working its way through the threads on the bleed nipple, and then into the bleed nipple and into the clear hose of the bleed kit. The air was definitely not coming from inside the cylinder, and was also not getting back into the cylinder.
I have not tried, but I guess a dab of grease on the outside of the bleed nipple, where it meets the cylinder, should solve this issue. Me, I just stopped worrying and got perfect results anyway.
BackPacker is offline
post #6 of 16 Old 03-20-2018, 05:22 PM
http://kirbysbrakebleeders.ecrater.com/
Easy simp and quickle. I kept putting off messing with it because I don't have 4 hands. For the 25-30 bucks for the speed bleeders, the job took 15-20 minutes with perfect results.
Bugzy and brutalguyracing like this.
post #7 of 16 Old 03-20-2018, 07:32 PM
Rolex's Avatar
I'm with BackPacker.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 16 Old 03-20-2018, 08:42 PM
This flat works:
https://www.tooltopia.com/private-br...ols-70852.aspx
After a few years of Mighty-Vacs, the mess, hand cramps, this tool does the job quickly and efficiently. You will need access to compressed air. Brake and clutch hydraulic system flushing and bleeding is a breeze.
MAZ4ME is offline
post #9 of 16 Old 03-20-2018, 09:56 PM
Speed bleeders cost half as much. But I used a air driven tool decades ago. Worked like a charm. Only the device I used was pressurizing one, not a vacuum maker.
post #10 of 16 Old 03-20-2018, 11:07 PM
Notacop...good tools didnt cost me money, they made me money. And if they didnt make me money, they at least saved me time and effort with professional results.
notacop likes this.
MAZ4ME is offline
