Battery recommendations? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 22 Old 03-20-2018, 11:00 AM Thread Starter
VSrider's Avatar
My original battery is approaching the six year mark and still is performing well but for peace of mind I am planning to replace it. Lots of threads on this already but for the sake of efficiency in ten words or less what batteries are recommended? Thanks in advance.
VSrider is offline
post #2 of 22 Old 03-20-2018, 11:19 AM
Lrobby99's Avatar
Lead-acid, and cheap, is my 2 cents.
Rides2Work, marcham and Hatchi like this.
Lrobby99 is offline
post #3 of 22 Old 03-20-2018, 11:24 AM
YUASA......I have already gone through "2" cheap batteries on my 2015 XT, the last YUASA I had in a bike lasted 6 years. My current YUASA cranks the engine over like a raped ape, my bike has never started like it does now. Oh and I am betting your original battery is a YUASA, if so that is yet another reason to get another.
post #4 of 22 Old 03-20-2018, 11:32 AM
Bikehigh's Avatar
Batteries are one of those things you can drive yourself nuts researching. Just head over to NAPA and get youself one of their Legend AGM batteries. ETX12 is the part number, $80 out the door. Bring your old battery in to swap and no core charge.
Bikehigh is offline
post #5 of 22 Old 03-20-2018, 12:00 PM
Lrobby99's Avatar
By "cheap" I did mean the Yuasa variety. Lead acid being cheaper than the fancy gel cell stuff, right?
Big B likes this.
Lrobby99 is offline
post #6 of 22 Old 03-20-2018, 12:24 PM
Numbercruncher's Avatar
You are correct. You aren't on a 450 MX bike where you want to save every pound you can. A good Yuasa or other name brand battery is the way to go. I'd try to buy from a place that has reasonable turnover so you don't get one that has been sitting around for a long time. But it may be that if the battery has never been setup it won't make a difference if it has been sitting on the shelf for two months or two years.
NC
Big B likes this.
Numbercruncher is offline
post #7 of 22 Old 03-20-2018, 01:33 PM
locoblanco's Avatar
AGM is the way to go. O'Reilly auto parts has the same thing, comparable price, if you don't have a Napa close by.
locoblanco is offline
post #8 of 22 Old 03-20-2018, 02:13 PM
Another vote for the YTX12-BS Yuasa (best). Don't let the shop fill it, diy per the instructions.
Hatchi is offline
post #9 of 22 Old 03-20-2018, 02:37 PM
Yuasa AGM is the only battery I install in the motorcycles I service. One of Yuasa's features is that they have a yearly catalog showing battery applications and specifications. With my battery testers I can check capacity against spec, usually during an oil change, and avoid an unpleasant surprise out on the road.
MAZ4ME is offline
post #10 of 22 Old 03-20-2018, 03:28 PM
Six years...replace with identical
wingstrom is offline
