A long shot, but... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 2 Post By G-Dub
  • 3 Post By notacop
post #1 of 5 Old 03-16-2018, 08:31 PM Thread Starter
A long shot, but...
My 2013 Adventure is recently experiencing something I’m not sure how to isolate the cause of. Once in a while when I go to start it, it gives me an F1 light and the fuel blocks on the dash blink sequentially. If I remove the seat and move a few wires for the aftermarket lights and a few other things, the issue goes away and it starts right up. Sometimes if I turn it off and then on, it goes away. Seems like a loose wire, but what under the seat would cause that? When it runs, it runs great and all of the add ons work fine too, including dash lights and headlights. I did most recently add an Eastern Beaver headlight relay and the McCruise system which works perfectly. Ideas? Thanks!
cforider is offline
post #2 of 5 Old 03-16-2018, 08:49 PM
Here's a long shot answer...loose battery terminal connections (or other main ground/power connections) can cause a host of random problems.
If that's not the culprit I would start unplugging and replugging every connector I could find.
Wallydog and Rides2Work like this.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #3 of 5 Old 03-21-2018, 12:30 AM
b177y's Avatar
How old is your battery?
I had similar weird electrical problems on my old FJR. The battery voltage metered just fine, but it was a 4 year old bike at the time with the original battery, so I replaced it and all of the weird lights and warnings disappeared.
'13 dl650A, 2014-present
'07 FJR1300, 2009-2013
'84-ish Honda CB400, 1994-1998
b177y is offline
post #4 of 5 Old 03-22-2018, 12:36 PM
A battery can be checked for voltage loss when you press the starter button. Have a meter on the battery and see what it does.
Those loose connections matter too. Don't just tighten your connections, take them loose and clean the connectors and the posts then reconnect.
Yes, you will have to reset the clock...bummer, man.
post #5 of 5 Old 03-29-2018, 05:28 AM
My money is on corrosion in the connector blocks above the radiator. I've previously had the above symptoms intermittently on my strom, which vanished after sorting those connectors.
uk-vstrom is offline
