Riser recommendation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 03-13-2018, 09:01 AM Thread Starter
Hey all,
I have a pair of 2" Rox risers but am starting to feel like they may be a bit overkill (combined with the fact that they're just a little difficult to get on considering cable length).
I really only need the bars to come BACK (not up at all) about 1/2 to 1 inch. Which risers would you guys recommend for that?
Thanks.
davidp80 is offline
post #2 of 14 Old 03-13-2018, 09:31 AM
The Rox risers I put on my BMW were very adjustable.
post #3 of 14 Old 03-13-2018, 10:02 AM
Highwayman2016's Avatar
Highwayman2016 is offline
post #4 of 14 Old 03-13-2018, 10:54 AM Thread Starter
Any leads on which risers are specifically designed to bring the bars back, rather than up?
Dave
davidp80 is offline
post #5 of 14 Old 03-14-2018, 06:22 PM Thread Starter
Giving this one a bump.
Anyone else have any thoughts on good risers to bring the bars back, rather than up? Just need an inch or less. Thanks!
davidp80 is offline
post #6 of 14 Old 03-14-2018, 07:11 PM
vinnyvavoom's Avatar
I have not seen risers that go back only. IMHO, I would avoid this anyway since it would bring the bars straight toward the tank and limit future tank bag options.
Have you considered just changing the handle bars to a set with a greater sweep. Or even just rotating yours toward the rear. (This is free to try it out, just a little time spent loosening and tightening things.)
_______________________________________________________________________________
There are 10 types of people, those who know binary and those who don't.
What I ride now:
2013 Honda GoldWing (The Lady)
2014 V-strom 650 (The Mistress)
Previously: 07 Ultra Classic, 95 Softail, 80 gs450l
vinnyvavoom is offline
post #7 of 14 Old 03-14-2018, 07:51 PM Thread Starter
Those are good recommendations, @vinnyvavoom . I hadn't thought about changing the bar setup or stock bar alternatives. Will look into that now.
Thanks!
davidp80 is offline
post #8 of 14 Old 03-14-2018, 09:50 PM
dmfdmf's Avatar
I want risers for my K7 but I don't want to deal with replacing cables either, especially the ABS line for the front brake because I dread bleeding my brakes again.
I don't think there is a way to make a riser that only goes back not up so bar replacement seems to be the only option there.
I found these risers from Advanced Motorcycle Products that go up 1.25" and back 5/8" or 1". The back offset of 5/8" is the smallest shift I've found in a riser so maybe I won't have to mess with the brake line. I haven't pulled the trigger yet (other mods higher on my list) but if you use these let us know how it works out. Thanks.
Next Up: ?
dmfdmf is offline
post #9 of 14 Old 03-16-2018, 06:14 PM Thread Starter
Managed to get the 2" Rox Risers on this afternoon after raising the forks 12mm. I don't think I could have done it without that. Raising the forks took all of about 15 minutes once I knew how to do it (some good posts on this forum).
The throttle cable is a little tight at a full left turn but I don't think it's dangerously so. I just removed a few cables from their guides and I'm not totally sure that was even necessary.
Dave
davidp80 is offline
post #10 of 14 Old 04-26-2018, 10:16 PM
I am looking at risers as well... but only for height. Any experience with the vibration dampening ones that Rox makes? What are some other options? Does anyone know the max height w/o changing cables?
ocoas likes this.
RealJPedersen is offline
