ABS Bypass - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By Rolex
post #1 of 5 Old 02-21-2018, 11:50 AM Thread Starter
biddysere's Avatar
ABS Bypass
My rear ABS is dead and I'm not buying a brand new one and can't find a used one so I am wanting to bypass the ABS line . Can I use a rear brake line from an earlier module (pre 2012) for this?
biddysere is offline
post #2 of 5 Old 02-21-2018, 01:47 PM
How do you know it is dead, and is the ABS light staying on?
Big B is online now
post #3 of 5 Old 02-22-2018, 01:17 AM
Rolex's Avatar
The rear brake "should" perform the same with or without the pump so a bypass "should" not be necessary.
Do you have a problem that is stopping your rear brake from working as it is ?
D.T. and notacop like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 5 Old 03-08-2018, 02:33 PM Thread Starter
biddysere's Avatar
The rear brake was frozen- couldn't depress it. I replaced the master and proceeded as usual with the bleeding process. The master was pumping but the bleeder would not draw fluid past the ABS module, it was locked in the shut mode. No light and still no light. I bypassed the rear ABS with a new brake line. Everything works fine now and $1K cheaper than replacing the ABS Module
post #5 of 5 Old 03-08-2018, 02:36 PM
D.T.'s Avatar
Sometimes you just gotta try yourself. Is it leaking fluid all over the place??
D.T. is offline
