Cotton in fork seals??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
  • 2 Post By wingstrom
  • 2 Post By greywolf
  • 1 Post By NEALSMO
  • 1 Post By PeteW
  • 1 Post By notacop
  • 1 Post By locoblanco
post #1 of 9 Old 01-24-2018, 09:41 PM Thread Starter
aTuWitty's Avatar
Hi friends! My new to me Glee has leaky fork seals, and when I took my Sealmate to them today, it hung up on something big under the dust seal. As I pulled it out, it looked like a large chunk of cotton or some other similar substance. Is this normal? Do these fork seals use something similar, or did a previous owner perhaps try a trick to stop the leaking? I was very confused, as I've never seen anything like it before. I ended up ruining my tool trying to remove the chunk of stuff.
"Definitely do not sit on a DL1000. Big mistake. You'll end up buying one. Happened to me. True story."
-busarider54
"Purchasing a V-Strom from a Harley dealer does have poetic justice. Almost like removing a talented child from a meth house."
-ShortOnSkill
"I'm for moves that will help people get over the idea that it is ever okay to drink and drive."
-greywolf
aTuWitty is offline
post #2 of 9 Old 01-24-2018, 10:16 PM
I always slide the dust seal up the fork tubes before using the Seal Mate. Iím not aware of a cotton substance unless itís part of the dust seal.
aTuWitty and Spec like this.
wingstrom is offline
post #3 of 9 Old 01-24-2018, 10:21 PM
Not OEM. It sounds like the seller did it to disguise the problem.
Big B and aTuWitty like this.
post #4 of 9 Old 01-24-2018, 11:13 PM Thread Starter
aTuWitty's Avatar
That's what I was thinking, Pat. I've ordered new seals and some new fork oil for good measure.
-busarider54
-ShortOnSkill
-greywolf
aTuWitty is offline
post #5 of 9 Old 01-25-2018, 11:13 AM
Look Black Labs cover on how to do the job. It is a great illustrated guide and takes some of the mystery out of the task.
post #6 of 9 Old 01-25-2018, 12:31 PM
NEALSMO's Avatar
Could have been used to mask a seal leak or just to work as an extra dust seal to protect the oil seal.
Spec likes this.
NEALSMO is offline
post #7 of 9 Old 01-25-2018, 06:56 PM
Just a comment, if there's more than 60,000k's on the bike the internal bearing surfaces need replacing as well. Pig of a job , but if you have the forks apart anyway you may as well do the sliders as well.
aTuWitty likes this.
PeteW is online now
post #8 of 9 Old 01-26-2018, 09:51 PM
i had a left side puker and replaced the seal and dust cover and it's all good now. That was at 80+K miles.
post #9 of 9 Old 01-27-2018, 08:17 AM
locoblanco's Avatar
My honda v65 sabre had felt washers under the rubber dust seal, stock. I don't think that's stock on the vstrom, however.
locoblanco is offline
