Suzuki Recalls for DL650s - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 137Likes
post #1 of 571 Old 12-21-2015, 10:07 AM Thread Starter
Supatramp's Avatar
Wonder if our U.S. bikes will be included?
Recalls
Supatramp is offline
post #2 of 571 Old 12-21-2015, 10:23 AM
Wire chafing under the tank and water in the connectors behind the radiator top shroud are issues world wide on the Vee2. I'd like to see more about where the contamination on the Glee cams occurred. The recalls seem to be only on Australian bikes right now. See the sticky thread in the Australia/New Zealand forum for details. https://www.stromtrooper.com/australi...0a-merged.html
post #3 of 571 Old 12-21-2015, 11:23 AM
D.T.'s Avatar
Tappets wear huh? Hmmm.
The tappet hardening surface may wear due to contamination causing tappet and camshaft wear. In the worst case scenario this may cause the engine to stop running.
New GSXS already has a front brake recall also.
Paul13DL likes this.
D.T. is offline
post #4 of 571 Old 12-22-2015, 05:39 PM
WeeMcD's Avatar
Wires under tank wore through insulation and shorted out the entire dash on my previously owned '07 DL650. That wasn't cheap to have fixed.
2007 DL 650 SOLD with 56k miles
2012 DL 650
1991 DR350S (dirty bike)
2004 DR 200 (wife's dirty bike)
Janitor, writer and editor of BestScenicRoutes.com. Explore It. Experience It.
Real name: Sean McDermott
WeeMcD is offline
post #5 of 571 Old 12-22-2015, 06:31 PM
I've never heard of that one. It is a problem on the Vee2 and some K4 or K5 Wees had a mis-routed wire bundle under the left side cover that caused a recall from chafing.
post #6 of 571 Old 12-23-2015, 03:54 AM
https://www.recalls.gov.au/content/i...mItemId/952843
What are the defects?
Since the DL's don't have tappets, I'm thinking improperly hardened shim buckets is the most likely, the surface starts spalling and the damage spreads. I can't see this being Oz only, but given there are 8 buckets in each bike simply shipping enough bits would be a challenge.
Pete
PeteW is offline
post #7 of 571 Old 12-23-2015, 09:37 AM
I'm thinking cam lobes and buckets are the parts that can be affected by contamination, maybe by cams not being cleaned well enough after grinding.
post #8 of 571 Old 12-26-2015, 03:55 PM
srpkcop's Avatar
Just read that the tappet/cam recall involves wee2s from 2013 to 2015 in Canada. I checked on the Transport Canada website but there's no mention of it yet.
2012 650 Expedition-well farkled
srpkcop is offline
post #9 of 571 Old 12-28-2015, 09:48 AM
Keep_it_on_the_DL's Avatar
Another article:
Multiple Suzuki Models Recalled for Valve Tappet and Cam Wear - Motorcycle.com News
I can't see this not affecting US bikes. Maybe I can get a free valve adjustment out of this.
2017 Honda Africa Twin DCT
2013 Honda CB1100
2015 Honda Grom
Keep_it_on_the_DL is offline
post #10 of 571 Old 12-28-2015, 09:58 AM
So all L3 and L4 (2013 and 2014) Glees with under 4000km as well as those with over 4000km having over spec valve clearances are the ones affected by the recall.
