Highway pegs, part two.. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 22Likes
post #1 of 31 Old 07-08-2015, 02:50 PM Thread Starter
DaveinNC's Avatar
I jury rigged some highway pegs for a Virginia trip that served their temporary purpose, now its time to do it correctly. I cut a 1/2 piece of iron bar, welded in a set of Kuryakin peg mounts. Welded two mounting bolt plates and will be using OEM takeoff footpegs, I replaced mine with Goldwing pegs. The welds need to be cleaned up, the assy needs to be blasted then painted with black epoxy frame paint, then I will mount them on two 7/8 three piece frame clamps attached to the crash bar crossover. This should look like a factory install when done and they will fold up when not in use. That really bugged me with the last set as well as this will have a much stronger mount point. These mad the long ride very comfortable but I always had concerns with hitting something with them or dragging the ground in the twisties. With the folding pegs that is a non issue, plus it will look a whole lot better.
Old bars
Layout
Kuryakin peg mount pivot
Weld up
eagleeye, NVDucati and driftertex like this.
"Dave"
2017 VFR1200X Crosstourer (Chili)
2016 GL1800 Goldwing, sold good riddance.
2013 V Strom DL650 Adventure AKA Max, Fun, different, did I say fun? (traded)
2004 FLHTC Ole Red, all lower 48, several times (sold 180k miles did lower 48 four times)
1999 FXST Stage 4 Evo AKA Bitch Bike and holeshot king
1998 FXDWG Red Grey (sold)
1997 XL (Mom's bike)
1976 XLCH Iron Head (Leaker)
1978 ZIR TC (AKA Smoky) Rated "R" not for kids under 17 (Seized by father)
1976 CB 750 (AKA trouble)
1976 MT 250 Elsinore (My favorite, rode the country on a 2 stroke)
1974 CB 350-F4 (AKA Dog)
1974 Kawi 100E (AKA Sparky the mud bug)
1972 KV 75 kawi
1970 Rupp mini bike
DaveinNC is offline
post #2 of 31 Old 07-08-2015, 06:42 PM
SECoda's Avatar
Nice work!
SECoda is offline
post #3 of 31 Old 07-09-2015, 08:55 AM Thread Starter
DaveinNC's Avatar
Thanks, welding and grinding finished, now I need to drill my mount holes in the two tabs and finish sand and paint. This is going to be nice.
"Dave"
1972 KV 75 kawi
1970 Rupp mini bike
DaveinNC is offline
post #4 of 31 Old 07-13-2015, 01:05 PM Thread Starter
DaveinNC's Avatar
I made a bad cut on the wrong line, had to start over, all finished now, welded them up, ground the welds neat, finish sanded and then sprayed with a frame epoxy. They work great, fold away when not in use and the OEM pegs look like they belong there.
SECoda, eagleeye and driftertex like this.
"Dave"
1972 KV 75 kawi
1970 Rupp mini bike
DaveinNC is offline
post #5 of 31 Old 07-13-2015, 02:12 PM
Damn Dave I love that set up, I would be more than willing to pay you to replicate me one too!!!!
DaveinNC likes this.
post #6 of 31 Old 07-13-2015, 02:21 PM
Those look great. You better patent that idea before someone takes it for their own. Really nice work...
noob75 is offline
post #7 of 31 Old 07-13-2015, 02:41 PM Thread Starter
DaveinNC's Avatar
Well, I had all the stuff laying around so my cost was paint and one piece of allthread. Not sure how much they would cost to buy all the parts and then build it. Maybe Rick will see them and start making them.
You need these
http://i230.photobucket.com/albums/e...c/IMG_4916.jpg
you need these
Drag Specialties Universal Three-Piece Frame Clamp, Black - 7/8 inch (Each)
16" of 1/2 ID iron Pipe
6" of 1" x 1/16" steel flat
16" of 5/16 threaded rod
1 set oem footpegs
3/8 SS hardware
1 can epoxy paint
The flange on the Kury peg mounts act as your pivot stop, the mount bolts act as a tension/friction spring. I wouldnt stand on them but you cant anyway... so....
The 3 piece frame clamps get mounted to the cross bar over several wraps of rubber splicing tape.
With the peg mounts perfectly vertical the offset on the pegs is at approximately 45 degrees, which is just perfect for me.
Weld up, clean and prep for paint, mount up, very simple project as long as you measure twice and cut correctly, unlike me. LOL
"Dave"
1972 KV 75 kawi
1970 Rupp mini bike
DaveinNC is offline
post #8 of 31 Old 07-13-2015, 02:50 PM
The_Boot's Avatar
Those look great! Nice work!
2009 Orange Wee
The_Boot is offline
post #9 of 31 Old 07-13-2015, 02:59 PM
GregB's Avatar
Good job very professional.
2014 650 Glee
GregB is offline
post #10 of 31 Old 07-17-2015, 09:48 PM
Captain Farkle's Avatar
Very clean looking. AWSOME!
2012 650 Vstrom Black - Givi E52 Maxia Trunk,Givi Quick Release PLR3101 Racks, Givi E21 Silver Side Cases, Admore LED Brake and turn signals, SW Motech Crash Guards, SW Motech Center Stand, SW Motech Steel Rear Rack, SW Motech Bar Risers, OEM lower Cowling, OEM lower Seat customized by Triple K Upolstery, OEM Hand Guards, Eastern Beaver PC8, Givi Airflow Windscreen, Aprilla Mirrors, Dan Vesel Highway Pegs and Back Rest, Oxford Sport Heated Grips, FendaExtenda, Sena 10C, CREE LED Headlight Kit,10w Cree LED Work Lights,INNOV Wifi Bullet Cam
Captain Farkle is offline
